Converting a mechanical fuel pump to an electric - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 6th, 2013, 10:19 PM   #1
jeepers48
jeepers48's Avatar
Post Converting a mechanical fuel pump to an electric
I recently swapped out my (0riginal) 8/10 gallon tank on my 55 Willys pickup and replaced it with a 21 gallon tank from a 1994 YJ w/ the oem electric fuel pump. At first start up, ran great so i went up to the gas station and threw another 15 gallons in the tank. tried to start up the willys (has a AMC 401 under the hood)which was now harder to start, kept flooding out/to much gas. Got it running but kept stalling out about a half dozen times.
Popped the hood and pulled the air filter, reeked with gas and looks like gas pushed thru my carb gaskets too?....... Im leaving the air cleaner off tonite so it dries out in and around the carb(670 truck avenger)
I realize i f***ed up. The motor is a 1977 amc401, had the mechanical pump on it.
Can i keep the 21 gallon tank w/fuel pump in? I do have a return line going back to the tank(and hooked up) Also, the gas filter im using is for a 1977(might be restricting gas on the return line?)
Buying a "fuel regulator, which one would work best for my application??? (brand, model,part no.) thx in advance.
jeepers48 is offline   Reply With Quote
Old May 7th, 2013, 05:56 AM   #2
RADRICK
RADRICK's Avatar
Do you have a regulator in the system now? If not you definatly need one. Pick a quality adjustabe one and plumb it in. I think 7-8 psi would be a good starting point, I've heard old timer jeeper used them and dialed down to 3-4 psi in the rocks to keep from flooding out on extreme angles.
Old May 7th, 2013, 08:48 AM   #3
Sandals
Fucking Zen as Shit
Sandals's Avatar
I'm running my stock YJ electric pump with a carb.
I have an adjustable regulator with a return line under the hood. Has worked well for me so far.
Old May 7th, 2013, 05:21 PM   #4
jeepers48
jeepers48's Avatar
Thx for the replys RADICK & Sandals. I picked up an adjustable regulator tonite.
Sandals, where did you mount your regulator, under the hood or the under side, along the frame?
I picked up a Holly 12-803 adjustable/ 4 1/2 to 9 pds.
Page generated in 0.16978 seconds with 35 queries
