99 jeep cherokee no start... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 6th, 2013, 03:36 PM   #1
ellsworthcj5
Madmudder amc360
ellsworthcj5's Avatar
Exclamation 99 jeep cherokee no start...
1999 cherokee 4.0 auto. Loaded ,ran great the day before, is a d.d no recent history of any problems.....went out in the morn. raining stopped at light quit running Cranked and wont start........
changes the crank position sensor... no start
changed the plugs and wires, rotor and cap.... no start
I have spark at wires.... today shows a no bus on display.. removed dash display and saw no rust on connections...
fuel gauge not working... smells gas.. cranks over great
Replaced.... Cap,rotor,plugs,wires.& position sensor..
no theft system is installed removed awhile ago.
Any ideas????????
ellsworthcj5 is offline   Reply With Quote
Old May 7th, 2013, 07:08 PM   #2
Dannn
Dannn's Avatar
can you scan it and get ahold of any codes?
Dannn is offline   Reply With Quote
Old May 7th, 2013, 10:26 PM   #3
jeepers48
jeepers48's Avatar
On my 2002 tj, to pull the codes, turn the ignition....on,off,on,off,on./3 times/leave it on at that point, it should flash a code. I would think it would work on a 99 xj. Good luck.
jeepers48 is offline   Reply With Quote
Old May 8th, 2013, 11:31 AM   #4
Dannn
Dannn's Avatar
Not if he's getting a no bus message
Page generated in 0.19866 seconds with 35 queries
