8.8 bearing/seal - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 3rd, 2013, 08:37 PM   #1
99tj4banger
99tj4banger's Avatar
Default 8.8 bearing/seal
I have a 8.8 out of a 97 explorer in the rear of my tj and the driver side seal is leaking at the wheel.
Any tips/tricks on changing that? I've never done one before.
99tj4banger is offline   Reply With Quote
Old May 4th, 2013, 01:38 AM   #2
deathbypsi
Brian R.
deathbypsi's Avatar
No tips or tricks really....if its just the seal all you gotta do is pry it out after you get the shaft out {assuming you know how to do that}
Old May 4th, 2013, 09:56 AM   #3
99tj4banger
Yeah I found a few write ups looks like the easiest way to remove the seal is actually using the axle shaft to pry it out. Hopefully my bearing is good and it will be an easy job.
Page generated in 0.19394 seconds with 32 queries
