TJ: 4.0L Misfire - Please Read - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 3rd, 2013, 08:16 PM   #1
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
Default 4.0L Misfire - Please Read
2002 TJ 4.0L 148k Miles
Alright so I'm starting to get real tired of all the repairs lately, it just seems like one after another. If you've seen my previous posts recently, you'd see that I was having steering play problems, luckily that is all take care of (finger crossed).
What is now happening is a problem I've been having for a long time, that I thought I fixed.
Symptoms: When driving the jeep at around 60-70 mph (2500-3000 rpms) my CEL will begin to flash signaling a misfire. It will then putter and when I pull up the code, I get the code for multiple/random misfire and a code for cylinder 3, 4, and 6. Well awhile back I thought it was fuel pump related because the fuel pressure was so low when I tested it, so I replaced the entire unit with a Spectra Premium. Shortly after, I still noticed at around 60-70 mph the CEL would flash. I've also replaced the spark plugs with both Champion OE and then tried Autolite Platinum. Replaced the Crank Position Sensor, Idle Air Control Sensor, and have thoroughly cleaned the throttle body.
Another strange symptom I have been having is when I first go to start it in the morning, I will start it, it will idle fine for about 5 seconds, and then begin to sputter for about 5 seconds and then fix itself, I am not sure if this is related or not.
Regardless, I really don't know what it could be anymore. Anyone else have the same problem or suggestion? I have read in the past 97-03 TJs have a problem with misfire after they change the Crank Sensor, but I am not sure...
Any advice/help is appreciated as always..
Catnip 0_o is offline   Reply With Quote
Old May 3rd, 2013, 08:19 PM   #2
Toyfish
Toyfish's Avatar
Change ur tps sensor
Sent from my DROID X2 using Tapatalk 2
Old May 3rd, 2013, 08:28 PM   #3
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
I would but one of the frickin Screws that holds it in wont cooperate
Old May 3rd, 2013, 08:35 PM   #4
Toyfish
Toyfish's Avatar
That sucks cu its prolly your issue
Old May 3rd, 2013, 08:37 PM   #5
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
I am suspecting the coil rail but I will drill out the screw that doesnt want to work with me and try that. Ive had a spare tps on hand for awhile
Old May 3rd, 2013, 08:39 PM   #6
Toyfish
Toyfish's Avatar
I may have a spare coil pack laying around at work cant remember it i scrapped it or not ill check on monday if ur tps dont fix the issue
Old May 3rd, 2013, 09:07 PM   #7
rammanriley
rammanriley's Avatar
Check it with a multimeter or scan tool.
rammanriley is offline   Reply With Quote
Old May 3rd, 2013, 10:53 PM   #8
Catnip 0_o
Martial Artist
Catnip 0_o's Avatar
Just replaced the tps, im doing the ignition coil as well regardless if the tps would fix it or not, i know the rail hasnt been changed since I bought it almost 3 years ago
Page generated in 0.25031 seconds with 47 queries
