As I wait here for roadside assistance (7.3 died no start) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 2nd, 2013, 10:50 PM   #1
14muddn
Default As I wait here for roadside assistance (7.3 died no start)
I'm wondering what I should start checking after I get a flatbed ride home. I unhooked my trailer at my shop and about a mile later I had a quick loss in power and than it died and would not start back up.
It cranks and the tach moves a little but shows no oil pressure (it never shows oil pressure in the dash till the truc starts).
The oil level is good on the dipstick it was recently changed
The level is good in the hpop reservoir
I unplugged my tuner nothing changed
I opened up the fuel bowl let it fill up and empty it again so I know I have fuel
It cranks strong so the 2 month old batteries are good.
I don't have a scanner so what should I start checking? CPS, ICP, IPR? Can they be checked without buying new ones? Maybe flush the blinker fluid and check the spark plugs?
Old May 2nd, 2013, 10:57 PM   #2
jaysusr
jaysusr's Avatar
Those last to thingies u mentioned should do ya
Old May 2nd, 2013, 11:07 PM   #3
MilwaukeeF350
Dan
My old 2000 F350 it will show up oil pressure on gauge after long crank like 10 seconds.
Did engine light came on? Sound like IPR blew o-ring. Before you do anything you need scanner to check ICP and IPR duty to see what going with 7.3L.
How many miles on it?
Old May 2nd, 2013, 11:07 PM   #4
masterbeatty
masterbeatty's Avatar
Check the valve cover harness driver side. Had one rub through and shut the truck down before
Old May 2nd, 2013, 11:08 PM   #5
masterbeatty
Should have said that better. Check the harness that goes over deiver valve cover big square plug
Old May 2nd, 2013, 11:11 PM   #6
Bones
Bones's Avatar
fuses. CPS
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old May 2nd, 2013, 11:11 PM   #7
hamsmotorsports
hamsmotorsports's Avatar
Scanner check rpm signal. Check icp need 600psi to start. If you can run a injector buzz test do that. One of these will useually point you in the right direction.
hamsmotorsports is offline   Reply With Quote
Old May 3rd, 2013, 11:42 AM   #8
14muddn
Dan, it has 202k mikes no check engine light, it turns off with the other lights when you turn the key.
I'm going to start with looking at the fuses>unplug IPR>unplug ICP>swap the CPS with the one in my other 7.3.
Again, I don't have a scanner... Since I have two 7.3's I'm realizing it wouldn't be a bad investment though. What's the best option for someone who just works on their own shit?
Old May 3rd, 2013, 12:14 PM   #9
montecarlo33
The Violator
montecarlo33's Avatar
I use a Bluetooth adaptor that I bought off ebay and the android app called TORQUE. there is a free and paid version, they are both nice and provide lots of info and when you do read the code, its one click to jump to the web browser where it gives you the whole description. Adaptor was only like 35 shipped. Works on any OBDII and is currently what I use in my LS swapped truck so I can read the computer because I don't have gauges in it yet.
Old May 3rd, 2013, 12:33 PM   #10
14muddn
That is the tits.
Wait, no it's not. I have an iPhone not droid.
Old May 3rd, 2013, 12:45 PM   #11
montecarlo33
The Violator
That is the tits.
I know the iphone has a different app, just google it I cant remember what its called.
Old May 3rd, 2013, 02:55 PM   #12
14muddn
UPDATE! I swapped my working cps from my '96 powerstroke into the '00 and it started up. Thanks Bones!
The bad CPS was a grey one and the working cps was the black one. It took a little longer than usual to crank but it seemed to idle smoother. Could this be because the grey one was going out or are they different?
Old May 28th, 2013, 02:35 PM   #13
John2001
John2001's Avatar
It could be or it could be something else. The black CPS is the one ford recalled, it's also the best one that no one makes any longer. So you don't end up stranded and have to ask why your truck died later down the road... Disconnect the fuel bowl heater wrap it with electrical tape and forget about it. When the fuel bowl heater fuse blows it will leave you stranded... Beat it to it you don't need it anyways
John2001 is offline   Reply With Quote
Old June 21st, 2013, 08:29 PM   #14
14muddn
Yeah had that happen on my '96... I disconnected the fuel bowl heater on both trucks that day.
Page generated in 0.45061 seconds with 65 queries
