Ram assist - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 2nd, 2013, 09:47 PM   #1
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Default Ram assist
Anyone run a ram assist setup on there axle? I'm looking at a 2wd steering box for crossover steering right now and it's been drilled for assist. If purchased i'll be putting it on my Dana 60. It'll help with steering as i now have a spool in the front. Just looking for some real life input on how they work.
Old May 3rd, 2013, 06:52 AM   #2
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I have been running assist on my Toyota and once you get the bugs worked out it does great. Just make sure the box was tapped correctly, make sure you have a big reservoir, and make sure you have a cooler for the fluid.
Old May 13th, 2013, 01:21 PM   #3
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
pm 89tbiguy
He was more than happy with his.
Also if you don't have a local hose shop give G.T. Rubber a call for your lines. 32 bucks for my lines with crimped fittings!
(989)-772-8151
Page generated in 0.12606 seconds with 32 queries
