Blow off valve bad? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 2nd, 2013, 07:40 PM   #1
92FleXj
stacks stacked on stacks
92FleXj's Avatar
Default Blow off valve bad?
Can a blow off valve go bad? When I'm in the highway at lower rpm an I give it gas to get up a hill or gain speed I can hear air leaking from under the hood. I maintain boost but something's not right.
And when it gets real bad it will flutter when it leaks.
It's a 2000 7.3
Old May 2nd, 2013, 07:50 PM   #2
kickstand
circling the drain
kickstand's Avatar
Do the rubber boots for your turbo have holes in them? Not uncommon.
Old May 2nd, 2013, 07:59 PM   #3
92FleXj
92FleXj's Avatar
No they're new.
It's defiantly coming from the blow off valve when it shifts and I'm on the gas I hear it blow off real loud than stays pretty constant but only about 1/3 of the loudness of the actual blow off
Old May 2nd, 2013, 08:04 PM   #4
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Yes, they can go bad.
But...unless you installed one on your truck you don't have one. Diesels don't have a throttle plate, therefore they don't have them. Only on built diesel motors will they become somewhat of a necessity.
You probably have a boost leak (obviously) somewhere. Check all lines, plumbing, etc. If you can fab a 2L bottle over the air intake and seal it with duct tape and then seal an air hose onto that you can make a booty fab boost leak checker. You probably only need 10-15 PSI to check for leaks.
Old May 2nd, 2013, 08:06 PM   #5
Bones
Bones's Avatar
you dont have a blow off valve
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old May 2nd, 2013, 08:15 PM   #6
kkodet
kkodet's Avatar
Following. I have same issue, same year and engine. Only difference is I have a Banks Stinger Kit.
Old May 2nd, 2013, 08:38 PM   #7
92FleXj
92FleXj's Avatar
if it was leak wouldn't i loose boost?
my truck 100% has a blow off valve. maybe it was installed by previous owner. not sure. ill have to look it over in the am when there is light.
Old May 2nd, 2013, 08:42 PM   #8
GreaseMonkey
Pew pew!
It may have one, but it's just their for looks.
You can have a leak on a turbo and not loose boost. With the size of the turbo you have, it can easily make up for a small audible leak due to the CFM it can flow.
Old May 2nd, 2013, 08:43 PM   #9
dreezy
Haggard Fab
dreezy's Avatar
Wastegate?
Old May 2nd, 2013, 08:47 PM   #10
Bones
Bones's Avatar
you have a back pressure valve, it is not an external blow off
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old May 2nd, 2013, 08:57 PM   #11
92FleXj
92FleXj's Avatar
Does a back pressure valve relieve pressure in to open air under the good?
Old May 2nd, 2013, 09:14 PM   #12
masterbeatty
masterbeatty's Avatar
yes. every 7.3 i have ever ridden in in super duty platform has done this. every one, my dads does it till this day almost 400k truck runs great.
Old May 2nd, 2013, 10:07 PM   #13
Bones
Bones's Avatar
I assume you mean "hood".
no, there is no external blow off.
do you have an open intake and exhaust?
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old May 3rd, 2013, 04:13 AM   #14
7.3X
Fullsize support vehicle
7.3X's Avatar
You in fact have a wastegate that is what you are hearing. Every 7.3 I have ever owned or been in do it to some degree some more some less. The hypothesis being the internal spring becomes weak with age and heat cycles. Mine has done it seemingly forever and I still make great boost.
Do not worry about it it will hurt nothing.
If it is a concern I am in Hartland bring it over and we will look at it.
7.3X is offline   Reply With Quote
Old May 3rd, 2013, 06:06 AM   #15
92FleXj
92FleXj's Avatar
I'm worried about loss of economy and power. I actually like the sound..
Old May 3rd, 2013, 06:09 AM   #16
92FleXj
92FleXj's Avatar
I have an intake that runs off my cowl hood. But that's not the problem. This has got progressively worse over the last 2 years.
I just re geared my truck and that made it do it worse. I'm assuming because the RPMs are higher?
Old May 3rd, 2013, 06:53 AM   #17
frdboy
frdboy's Avatar
pics of what you are talking about (blow off valve?) might help. Sounds like an intercooler boot leak to me.
Old May 3rd, 2013, 08:00 AM   #18
92FleXj
92FleXj's Avatar
Old May 3rd, 2013, 08:24 AM   #19
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
Your truck does not have a blow off valve...repeat it does not have a blow off valve. They are not an easy add on to a diesel, and they were not there from the factory. Instead of posting a picture of whatever part you were looking at so people can call you dumb, you posted some bullshit video that shows nothing
Old May 3rd, 2013, 08:32 AM   #20
92FleXj
92FleXj's Avatar
It's a video of the sound you limp dick faggot fucker. I don't know where the sound is coming from to post a pic of..
Page generated in 0.46706 seconds with 84 queries
