chevy 4.3 cpi help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 1st, 2013, 01:39 PM   #1
Jritola51
Exclamation chevy 4.3 cpi help
Ok so I have a 1993 s10 blazer 4.3 cpi vin number w. It ran fine then started running rough and not idling. I started by replacing cap & plugs and really didn't change any thing so I replaced the fuel regulator and no start. Then I did a leak down test and found a leak in the injector and replaced spider injector and lines "nut kit". Did a leak down test with the key on I had 57 psi and after a minute it leaked down to about 48 psi. Still wont start even with starting fluid. Another note my oil was over full and had a gas smell so I changed that and filter.
Jritola51 is offline   Reply With Quote
Old May 9th, 2013, 08:02 PM   #2
Iggy
Iggy's Avatar
Not that is has anything to do with the fuel pressure, but check your coil - sound like you are not getting any spark.
Iggy is offline   Reply With Quote
Page generated in 0.18867 seconds with 29 queries
