1986 Bronco II - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 1st, 2013, 09:35 AM   #1
tweak177
Say what?!?
tweak177's Avatar
Default 1986 Bronco II
A porter at work her has a Bronco II 2.9L. No start. Its not getting any fuel. You can spray carb cleaner and it'll fire. I checked the 4 way connector at the fuel pump with my test light. I have 2 good grounds, a 12 volt that comes on solid when ignition is turned on then it will start flashing, and nothing for the 4th wire.
The wiring has been cobbled up pretty bad. What should I have at the fuel pump connector? Also it is a new pump. Thank, and sorry if this is a little confusing, typing this all on my phone.
tweak177 is offline   Reply With Quote
Old May 1st, 2013, 10:40 AM   #2
tweak177
Say what?!?
tweak177's Avatar
Fixed, bad relay.
Page generated in 0.17593 seconds with 29 queries
