Would you go Dana 60 or Dana 60? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 15th, 2013, 12:43 PM   #21
kickstand
circling the drain
kickstand's Avatar
RockSolid Perf.
Old May 15th, 2013, 03:51 PM   #22
mschaffer66
mschaffer66's Avatar
Originally Posted by Bones View Post
I STILL do not understand why people are concerned about unit bearings and ball joints. Buy good products and they will hold up
x2. But what do I know. I don't build anything.
If I did it again I think I would have gone with a UB/BJ D60. Yeah old school hubs are rebuildable and blah blah blah, but for as often as a UB is actually going to go bad I can deal with it being a throw away part.
Old May 18th, 2013, 11:45 AM   #23
kkodet
kkodet's Avatar
I STILL do not understand why people are concerned about unit bearings and ball joints. Buy good products and they will hold up.
13 races on the 4400 buggy and I replaced exactly 0 unit bearings (I even ripped the knuckle off the axle and the uni bearing was fine). I DID replace the balljoints twice. Once was preventative maintenancebefor KOH, and the other was after landing in a washout which sheared my knuckle off (mentioned above).
Not to mention my tire/wheel combo is about 144 lbs per corner...
also as mentioned, rock solid has an awesome high steer kit that really isn't that expensive.
For what you are doing your setup should be fine. As for strength of kingpin vs. balljoint I believe them to be comparable. The only benefit of kingpin for me is the cheaper price of highsteer and aftermarket components (plus I have kingpin 60 parts up the wazoo in stock already)
Now, as for unit bearing vs. rebuildable, there is a great difference, and that is the long term wear that you would not see on your buggy. From an engineering standpoint most unit bearings are weaker because they are much narrower from bearing race to bearing race internally. Thus the taller/heavier/wider wheel/tire combos put more stress on them that they would on wider race rebuildables. Day to day driving with big tires can eat up unit bearings fast.
Another big difference is water and mud, which on a trail rig is always a concern. Heavy mud and water fording will push contaminants into the hubs, no matter what the design. A little grease is alot cheaper than new bearings.
With all that being said I am swapping a unit bearing Dana 60 into the Excursion with 37 inch rubber, eventually. So we'll see how it holds up!
Old May 18th, 2013, 01:37 PM   #24
Elvis13
I've never seen a dually excursion so i'm assuming you're planning on a SRW. Do not forget that ALL SRW superduties ran 50's from 99 to sometime in '02. This narrows your search possibilities down to a couple 02's, 03's and 04's F-350's.
Old May 18th, 2013, 02:47 PM   #25
kkodet
kkodet's Avatar
Yup, as I already posted, I have an '03 60 I paid $375 for.
Old May 18th, 2013, 04:05 PM   #26
lgottler
lgottler's Avatar
I think you should convert it to 2wd. Gas savings, weight savings, etc. Face it, with a dozen people riding around in there by the time you load everyone up and get ready, then when you get to the trail head it will be time to turn around and go home!
lgottler is offline   Reply With Quote
Old May 18th, 2013, 05:03 PM   #27
Lousypirate
Whoop Whoop
Lousypirate's Avatar
If it is already 4wd, leave it 4wd. I know this is sarcasm.
I would go path of last resistance, option 1. Quality rebuild and go. Chapter in long run to justify replacing parts as maintenance.
Mary Jane (46 CJ2a)
The Kernel (46 CJ2a)
Wow, i would lick those...
Old May 18th, 2013, 06:16 PM   #28
kkodet
kkodet's Avatar
Hmm, a slammed Excursion would look sweet, lol :D
Old May 19th, 2013, 08:42 PM   #29
cerial
Direct Drive FTW
cerial's Avatar
14/50 hybrid(to match your bolt pattern and junk).
Or build a 14 steering.
http://www.powerblocktv.com/episodes...wheeler-part-3
I could not find the one where he builds a 14/50 hybrid but the tech is out there. Think it was on trucks actually.
Old May 19th, 2013, 08:51 PM   #30
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
High steer is not expensive. Talk to ROCKSOLID performance. What is wrong with unit bearings? Why build a steering 14b? A 35 spline 60 shaft is just as beefy as a 14b shaft. The 14b has the extra pinion support but you are putting the strain on the coast side of the gears. If you aren't going to buy the fancy bling shafts and locker what are you gaining?
Old May 19th, 2013, 09:55 PM   #31
kkodet
kkodet's Avatar
Exactly, kinda. A coarse 30 spline 14 shaft is actually weaker than a fine spline 35 spline shaft by almost 3,000 ft. lbs. of shear torque. Plus a 14 bolt housing is nodular iron (takes special rod to weld to) and 14 bolts have crappy ground clearance, and not as much strength as a reverse cut 60 ring and pinion. A 14/50 axle doesn't gain much.
Old May 19th, 2013, 09:59 PM   #32
chadcooper55
You can shave the hell out of a 14b and that helps with ground clearance. The one on my buggy ended up with almost the clearance of a Dana 44. It doesn't help the low pinion though.
Page generated in 0.39182 seconds with 60 queries
