Would you go Dana 60 or Dana 60? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 1st, 2013, 08:15 AM   #1
kkodet
kkodet's Avatar
Default Would you go Dana 60 or Dana 60?
I plan to upgrade the front axle in my Excursion, as I will be getting rid of the Dana 50 when I go with 37's.
Option one: Bolt in 99-04 Super Duty Dana 60.
Pros: Complete bolt in, ABS stuff works
Cons: Ball joint knuckles, high steer expensive, unit bearings.
Option 2: 1986-91 Ford F-350 Dana 60
Pros: Near a bolt in, spring perch width same. Kingpin knuckles allow more highsteer options. More aftermarket support. Rebuildable hubs.
Cons: Steering may require some fab, wheel bolt pattern different, no ABS.
So, I really don't care about the ABS, but I want the wheel bolt pattern to match front and rear, which means redrilling one of the axles and rotors. Steering fab is not too big of an issue.
I have neither axle yet and am shopping. Which way would you go?
Old May 1st, 2013, 08:29 AM   #2
1 and talk with rock solid about high steer. They have been doing a lot with these axles.
And don't be scared of ball joints. Replace them with a quality joint. I wheeled the shit out of my ball joint 60 on 40s and full hydro and never had an issue. Twisted the pass tube in the housing twice and eventually bent both tubes. But ball joints were never a problem.
Old May 1st, 2013, 09:13 AM   #3
Bones
Bones's Avatar
I STILL do not understand why people are concerned about unit bearings and ball joints. Buy good products and they will hold up.
13 races on the 4400 buggy and I replaced exactly 0 unit bearings (I even ripped the knuckle off the axle and the uni bearing was fine). I DID replace the balljoints twice. Once was preventative maintenancebefor KOH, and the other was after landing in a washout which sheared my knuckle off (mentioned above).
Not to mention my tire/wheel combo is about 144 lbs per corner...
also as mentioned, rock solid has an awesome high steer kit that really isn't that expensive.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old May 1st, 2013, 09:35 AM   #4
jerm97xj
I fixed it!!!
jerm97xj's Avatar
^^^^Thats a bad ass picture right there^^^ Sorry to hijack the thread.
jerm97xj is offline   Reply With Quote
Old May 1st, 2013, 09:54 AM   #5
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Also consider that the factory king pin knuckles are weak....with hysteer on something as heavy as a diesel excursion with 37's it will be 100% necessary to go with after market knuckles which are $$$...the super duty knuckles are alot stronger and rock solids hysteer is .
What about going the other way and getting a 05+ super duty 60 so you already have 1.5" 35 spline outers as well as heavier tubes and even beefier knuckles?
Old May 1st, 2013, 10:08 AM   #6
Bleay
sick of jackstand wheelin
Bleay's Avatar
Do you really need a d60? A d50 is a reverse rotation 9" ring gear. Reverse rotation in the front is slightly stronger than regular rotation. Are you going to throw a spool in it and rock crawl with an excursion?
Bleay is offline   Reply With Quote
Old May 1st, 2013, 10:40 AM   #7
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
I'm not sure why people don't like the Dana 50 either...it plenty strong enough
Old May 1st, 2013, 10:46 AM   #8
Bones
Bones's Avatar
pinion dia and neck down shafts... But if the truck already had a 50 in it, I would just leave it in for sure...
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old May 2nd, 2013, 08:17 AM   #9
kkodet
kkodet's Avatar
The Ford 60's also have high pinion. Both old and new style.
Old May 2nd, 2013, 08:17 AM   #10
kkodet
kkodet's Avatar
30 spline inners. Same as a Dana 44.
Old May 2nd, 2013, 08:24 AM   #11
kkodet
kkodet's Avatar
Alright great thoughts here. The strength of balljoints is not a concern to me, the advantage I saw about kingpin was the better steering options only. But thank you guys for the above suggestions, I will definitely be checking those out. That may swing my vote towards a Superduty axle.
As for unit bearings, they are not horrible, but in my experience they just don't hold up like the old stuff. I probably put 4-5 "high quality" ones on my XJ with stock tires in the 150,000 miles I drove it.
Old May 2nd, 2013, 08:27 AM   #12
kkodet
kkodet's Avatar
I haven't seen those up close out of a truck. I know those are radius arm axles and the thought has crossed my mind to "update" my Excursion suspension to the new style. However do you or anyone else know if there is enough room on those axles to run them under leafs?
Old May 2nd, 2013, 08:40 AM   #13
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I believe the radius arm brackets are just welded on so they can reasonably be removed unlike the old cast wedges....i don't know about putting a spring perch on the drivers side but i would think it could be done.
Old May 2nd, 2013, 09:06 AM   #14
Bones
Bones's Avatar
you won't be able to use the full turning radius if you are running leaf springs.
For simplicity, I would run what you have until you actually start breaking stuff. Even then, I would just carry spares. You can get D50 inners pretty much for free.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old May 2nd, 2013, 01:32 PM   #15
kkodet
kkodet's Avatar
As for the "keep the 50" comments, I don't want to put any money into this axle. Plus I have several Dana 60 Detroits already and a variety of gear sets and other parts.
Old May 13th, 2013, 10:41 PM   #16
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
I agree with what everyone else said. If you have a Dana 50 now just rebuild all the steering parts, unit bearing and new ball joints now and then find a 60 housing when you can. That way you can swap all those parts over and your good to go.
I'm the man in White.
Old May 14th, 2013, 06:27 AM   #17
kickstand
circling the drain
kickstand's Avatar
how about an update?
Old May 14th, 2013, 06:58 AM   #18
kkodet
kkodet's Avatar
Lol, yeah forgot.
I grabbed a 2003 Superduty Dana 60 with the right gears and all the steering stuff on it for $375. I plan to clean it up, toss one of my Detroits in it, and swap it in.
Old May 14th, 2013, 07:56 AM   #19
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
If you want any bling parts for it make sure to talk to ROCKSOLID performance. Their high steer arms and machines knuckles are awesome. They also redrilled mine to 8 on 6.5 for me. Great guys!
Old May 15th, 2013, 07:22 AM   #20
kkodet
kkodet's Avatar
Will do! Thanks for the heads up! Do you know if they are on here, or a supporter of GLFWDA?
Page generated in 0.37080 seconds with 83 queries
