Stupid as F@#^ - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 30th, 2013, 07:43 PM   #1
amc78cj7
amc78cj7's Avatar
Default Stupid as F@#^
We've been building this early bronco from scratch for several years and I'm planning to prime the 302 engine this weekend. I SWEAR I bought a case of Mobil 1 oil a month ago, and don't see the box lying around the barn; yet when I check the oil dipstick it is dry as a bone. Wouldn't it show up on the dipstick even if it were sitting at the bottom of the pan prior to being primed? I hate to have to drain it only to find that it was full...
I'm not quoting idiots who promote unsafe recovery strap techniques anymore. :miff:
amc78cj7 is offline   Reply With Quote
Old April 30th, 2013, 07:57 PM   #2
Bigredgmc98
Not afraid of crossbows
Bigredgmc98's Avatar
Not positive on the fords... But every Chevy i have ever owned the oil should definately be on the dipstick or its more than 1.5-2 quarts low.
Bigredgmc98 is offline   Reply With Quote
Old April 30th, 2013, 08:18 PM   #3
koochman450r
koochman450r's Avatar
Take drain plug out. If oil comes out put plug in fast. Add oil till on dipstick
you won this battle.
Old April 30th, 2013, 08:58 PM   #4
frdtrckmnrich
FORD The Best Never Rest
frdtrckmnrich's Avatar
If there is adequate oil in it, it would show up on the dipstick.
Old April 30th, 2013, 09:00 PM   #5
amc78cj7
amc78cj7's Avatar
Yeah, I'll just check it for oil first then add as I go. I may have added 5 qts., and since it is a fresh motor with new filter it might need 6 to fill. Must be getting old. Can't even remember filling oil a month ago...
Old April 30th, 2013, 09:01 PM   #6
firehawk
Live Action!
firehawk's Avatar
It should defintitely show oil on the dipstick assuming you have the correct one in there.
Pull the distributor and prime it that way before firing it, always a good idea if it hasn't been run in a while or a fresh rebuild.
Old April 30th, 2013, 09:08 PM   #7
amc78cj7
amc78cj7's Avatar
That's the plan for the weekend. Since I got the engine "used" I was worried that the dipstick may be wrong, but if I see the oil show on the dipstick with another quart then I'll assume I'm good to go.
Old April 30th, 2013, 09:13 PM   #8
XLJetsFan52
Just a good ole' boy
XLJetsFan52's Avatar
Ive never messed with a newly primed engine, but at work this is how i determine how low a car is. If theres nothing on the stick, its at least 2 qts. low. If oil reads at the bottom of the 'operating/safe' zone, then you are a 1 qt low.
XLJetsFan52 is offline   Reply With Quote
Old April 30th, 2013, 09:15 PM   #9
Toyfish
Toyfish's Avatar
X2
Sent from my DROID X2 using Tapatalk 2
Old April 30th, 2013, 09:20 PM   #10
charmander
charmander's Avatar
If anything I would guess that it would read high not being primed. If it was primed you would have a bit of oil in the filter and top end.
charmander is offline   Reply With Quote
Old April 30th, 2013, 09:22 PM   #11
Bones
Bones's Avatar
tap on the pan with something metal. empty pans sound like empty pans.
Or just go get more oil...
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 30th, 2013, 09:39 PM   #12
firehawk
Live Action!
firehawk's Avatar
Truth!
Old May 1st, 2013, 07:19 PM   #13
amc78cj7
amc78cj7's Avatar
Well there was oil in the pan. I plugged it again, so I not only don't recall how much I originally added, but also don't know how much is currently there. I'll add a quart at a time until it registers on the dipstick. If it takes more than 2 quarts I may just empty it and start from scratch.
Old May 1st, 2013, 07:21 PM   #14
Bones
Bones's Avatar
are you sure you have the right dipstick???
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old May 1st, 2013, 07:26 PM   #15
jaysusr
jaysusr's Avatar
Lemme ask ya this....why are u running Mobil 1 on a fresh rebuild? I run diesel oil like rotilla for break in because its got zink.
Old May 1st, 2013, 07:57 PM   #16
firehawk
Live Action!
firehawk's Avatar
x2
Do not use synthetic oil for break in.
Or just the cheap auto parts store stuff.
Old May 1st, 2013, 08:01 PM   #17
Toyfish
Toyfish's Avatar
x2
X2 on the cheap oil i use carquest brand oil for break in
Old May 1st, 2013, 08:44 PM   #18
amc78cj7
amc78cj7's Avatar
I've researched this and have read that zinc levels are the same in the mobil 1; although I've also read to add the zinc additive to any oil during break in. Although I suppose I'm wasting money...
Old May 1st, 2013, 08:48 PM   #19
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
You're seriously asking how to check a dip stick, yet plan on firing up a fresh motor?
Old May 1st, 2013, 09:02 PM   #20
amc78cj7
amc78cj7's Avatar
No, I'm not asking how to check a dipstick, and I have rebuilt engines before. I was concerned that I have the wrong dipstick and didn't want to overfill the engine with oil.
Page generated in 0.38705 seconds with 83 queries
