XJ: replaced trans now knocking sound - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 30th, 2013, 07:02 PM   #1
Jleach0696
Jleach0696's Avatar
Default replaced trans now knocking sound
jeep trans or torque converter was shot just replaced with a used one from a newer jeep now theres a little knocking sound from the bellhousing while that gets worse while coasting and the jeep seams low on power cant get it to spin the tires even around a corner
has new engine and trans mounts
Jleach0696 is offline   Reply With Quote
Old May 1st, 2013, 04:47 AM   #2
Tweeternpi
Tweeternpi's Avatar
Check the bolts on torque converter. If they are lose it will sound like knocking.
Tweeternpi is offline   Reply With Quote
Old May 1st, 2013, 07:15 AM   #3
tom tom
tom tom's Avatar
Yes double check the bolts. Also are you sure the converter is seated right.
tom tom is offline   Reply With Quote
Old May 1st, 2013, 07:33 AM   #4
rargreen
88
rargreen's Avatar
Did you use the correct torque coverter bolts? Some times there isn't enough clearance for standard headed bolts.
rargreen is online now   Reply With Quote
Old May 1st, 2013, 12:32 PM   #5
Jleach0696
Jleach0696's Avatar
checking converter bolts but i double checked they were tight when i installed it . there is also a whining noise that doesnt start until its moving and it sounds worse when coasting .
the torque converter did go in kinda hard and took alot of messing with to get it in but when compared to the old trans it looked like it was seated just as deep
Old May 1st, 2013, 07:51 PM   #6
skife
skife's Avatar
lose torque converter bolts are pretty common on 4.0s
my last one did it and my current one is like that, i need to get down and tighten them
Old May 3rd, 2013, 12:29 AM   #7
Jleach0696
Jleach0696's Avatar
i checked the torque converter bolts are tight and they are the original bolts.
it makes the sound whenever the engine is running in all gears and theres more vibration then before the swap. i got a rebuilt trans that was supposed to be for the stroker im gonna try. while its off is it safe to put a bellhousing and cps on and run the engine without a torque converter or trans attached to make sure the engine isnt causing the vibration ?
Old June 2nd, 2013, 10:04 AM   #8
Jleach0696
Jleach0696's Avatar
Page generated in 0.38619 seconds with 47 queries
