Electrical guys, quick question. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 28th, 2013, 12:27 PM   #1
Tie Dyed
O.G.
Tie Dyed's Avatar
Send a message via AIM to Tie Dyed
Default Electrical guys, quick question.
So, after my wife tried to burn down the house with her hair dryer, I put in a dedicated 20 amp GFI plug in the bathroom. My stove is on the other side of the wall, and I would like to put in a microwave above it. Any problems adding a plug off the bathroom one to run the microwave?
Thanks
2000 XJ with a 3 inch body lift
Tie Dyed is offline   Reply With Quote
Old April 28th, 2013, 12:29 PM   #2
firehawk
Live Action!
firehawk's Avatar
Microwave should be on its own circuit if possible.
Old April 28th, 2013, 12:50 PM   #3
daxl350
daxl350's Avatar
If the hair dryer is on and the micro is on at the same time BANG GOES THE BREAKER
thay both require there own 20 amp ckt
daxl350 is offline   Reply With Quote
Old April 28th, 2013, 01:21 PM   #4
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Your nuker needs its own circuit. That's it.
Old April 28th, 2013, 01:31 PM   #5
Immortal
NO RELIGION WAT!
Immortal's Avatar
What the hell. Go for it.
Old April 28th, 2013, 01:42 PM   #6
rammanriley
rammanriley's Avatar
The only question in this thread that needs answering is whats a Dikfore???
Hehe
96 Ram 1500 ECSB 5.9l v8 4x4 On 35's
13 Dart Aero (turbo go fast)
rammanriley is offline   Reply With Quote
Old April 28th, 2013, 01:54 PM   #7
aber61
aber61's Avatar
What they said, except for #5 & #6.
aber61 is offline   Reply With Quote
Old April 28th, 2013, 02:05 PM   #8
Yeah, both those are high draw, and should use separate circuits. Code requires they are separate (I know people aren't always interested in code).
Old April 28th, 2013, 02:10 PM   #9
bigbchevy
missmrgreenagain
bigbchevy's Avatar
This
H.o.r.e
Old April 28th, 2013, 02:13 PM   #10
firehawk
Live Action!
firehawk's Avatar
Morse code is more funn
Old April 28th, 2013, 02:29 PM   #11
Tie Dyed
O.G.
Tie Dyed's Avatar
Okay, well, after the small bathroom fire, I will have to add a new plug. Not worth risking it.
Old April 28th, 2013, 02:56 PM   #12
clarkstoncracker
lol
clarkstoncracker's Avatar
You're not going to cause a fire, but it's shady to do that.
Common microwave takes 1000w, so that is 8 amps. I doubt the hair dryer takes more than 8 as well, so if you installed 12 wire and have a 20 amp breaker, you will be fine.
If you put 14 or 16 wire on a 20 amp breaker, you better have good house insurance.
Old April 28th, 2013, 03:08 PM   #13
Typical hair dryer is in the ~1800 watt range (15 amps). 1875 seems to be the typical number I see, I suspect thats about as much as you can push on the typical older 15 amp circuit without nuisance trips.
Common microwave is 1000watts, but thats output power. 1500 watts input is typical for that output power. plus if its over the range, there's the range lights and blower, also. Checked out 1000 watt GE, its plate states 1.5kW.
Old April 28th, 2013, 03:11 PM   #14
Tie Dyed
O.G.
Tie Dyed's Avatar
I have a clear run up the wall to add the plug into the cupboard, and extra spots in my circuit box. I have everything but the breaker, so I will just do it right.
Old April 29th, 2013, 06:37 AM   #15
clarkstoncracker
lol
wow, my over the range is 1860W!
On a side note, an inverter microwave might be the best thing I've ever purchased in my life.
Old April 29th, 2013, 08:51 AM   #16
BlooMule
Old School
BlooMule's Avatar
I just looked at the microwave I have at work- it's 400w.
No wonder it takes 4 minutes to make ramen noodles.
-rw-rw-rw
Old April 29th, 2013, 10:27 AM   #17
Sandals
Fucking Zen as Shit
Sandals's Avatar
Replace 20 AMP GFCI breaker with a 40 AMP, problem solved
Old April 29th, 2013, 12:30 PM   #18
lol...
Old April 29th, 2013, 12:32 PM   #19
But this is funny, because its how many homeowners actually seem to think when doing electrical (or HVAC or plumbing, or whatever).
Most of the time, doing things the right way isn't much harder, and sometimes easier, than some of the hack jobs that I see.
Old April 30th, 2013, 10:06 AM   #20
Sandals
Fucking Zen as Shit
Sandals's Avatar
Oh I know, I've re-wired half of this house already.
Some really strange things in the breaker panel and in the walls.
Page generated in 0.37507 seconds with 82 queries
