9" Moser shaft seals - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 28th, 2013, 10:44 AM   #1
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Default 9" Moser shaft seals
Both ends of my 9" are leaking. Not sure if its due to me welding on a truss or not .....
I see there are a few different variations of seals/bearings that are used.
Mine has fluid in the tubes and uses tapper bearings that are not sealed. So it uses the gear oil to lubricate them.
I assume I cannot do this on my own as there is a pressed collar that holes the bearing on, which the seal is behind. Where do you get this done at ?
Jeep is in Kalamazoo as well
Old April 28th, 2013, 11:24 AM   #2
The seal is static (non rotating) in the housing and between the bearing and wheel flange. I found that a good layer of RTV solved the problem. As far as removing the bearing, you will pretty much destroy the bearing as it's a tight press fit. You can cut them off with a cutoff wheel or carefully with a torch. Most quality auto parts places can press them back on.
BTW, it doesn't have anything to do with them being Moser's.
Old April 28th, 2013, 11:51 AM   #3
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I could of sworn it was between the axle flange and bearing.
I'll take a look when its nice out. Thanks Rhino.
Old April 28th, 2013, 02:13 PM   #4
It is between the flange & bearing ................. but it seals to the housing bore. RTV it there.
Old May 10th, 2013, 02:17 PM   #5
John D
John D's Avatar
Mine leaked on one side. I tried a couple bearings, seals, retainers, rtv... Everything I could think of without success. Then I talked to BJ at Rock Solid in Cedar Springs and he set me up with bearings that have an o-ring around the outside. I haven't lost a drop of oil since. I don't remember the PN or manufacture, but if you call Rock Solid they can help you. Try the rtv first tho, some people have success with it.
Old May 12th, 2013, 04:23 PM   #6
My o-ring style leaked too. Plus it makes a thinner cross section and I broke the outer race on 2 different bearings.
Old May 12th, 2013, 04:35 PM   #7
curbdog17
Mini Van
curbdog17's Avatar
Both of mine leak, I just keep adding oil. :)
Page generated in 0.23768 seconds with 44 queries
