Tj v8 swap info help!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 27th, 2013, 10:43 PM   #1
TJ SKWIG
Professional Dumbass
TJ SKWIG's Avatar
Default Tj v8 swap info help!!
im swapping in a 5.7L vortec/ 4l60 out of a 1997 silverado into my 2002 tj. just wondering if anybody has done this swap and if i could get any help with the wiring of the new motor.. id like to retain the factory wiring harness instead of spending a shitload of money for a new harness.. what wires do i need to keep to make it run, etc?? any help or links would be greatly appreciated.
TJ SKWIG is offline   Reply With Quote
Old April 28th, 2013, 07:44 AM   #2
Do you have the wiring harness for your 5.7? Send it out to Jim's performance and he will trim it down to just what you need. You will only have to hook up 5 or 6 wires. Then you can trim out anything from the hold harness you don't need.
Old April 28th, 2013, 08:05 AM   #3
jbeemer
Built not bought!!
jbeemer's Avatar
If you want to do the harness yourself all of the info is at www.lt1swap.com. All of the pinouts and required wires are posted there.
jbeemer is offline   Reply With Quote
Page generated in 0.12054 seconds with 32 queries
