ZJ: Lift advice - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 27th, 2013, 10:34 AM   #1
Badphish
Default Lift advice
I'm lift my zj and piecing together a lift this is what I have so far
RE 4.5 springs front and rear
RE adjustable trac bars front and rear
BDS quick disconect sway bar links
front fixed lca (used new bushings)
rear adjustable uca (used new bushings)
These items I know I need
adjustable front uca
fixed rear lca
longer front brake lines
Bump stops What has worked for you?
Shocks ( will order after lift is installed for proper fitment)
What else am I missing?
Badphish is offline   Reply With Quote
Old April 27th, 2013, 10:38 AM   #2
montecarlo33
The Violator
montecarlo33's Avatar
Looks like you forgot about T-case drop spacers or SYE
Old April 27th, 2013, 11:57 AM   #3
skife
skife's Avatar
hack and tap!
Old April 27th, 2013, 12:32 PM   #4
jbsjunk
Little Member
jbsjunk's Avatar
Drill and tap the diff end of the bump stop inside the coil spring for a 3" body lift puck.
Old April 27th, 2013, 09:35 PM   #5
Badphish
from what I've seen shouldn't need a transfer case drop with a zj
Page generated in 0.19512 seconds with 38 queries
