05 F Series.. Seat belt alarm removal.. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 23rd, 2005, 07:54 AM   #1
clarkstoncracker
lol
clarkstoncracker's Avatar
Default 05 F Series.. Seat belt alarm removal..
Does anybody know how to stop the chime from going off? I sit in my truck at jobsites alot, and I have to stay buckled in or the damn chime goes off.
On my 04 F series, I just unplugged the quick connector going to the seatbelt itself, the newer truck doesn't have that.
Old December 23rd, 2005, 08:01 AM   #2
Hmm, damn, at work I have the specs for the 05 F-150 cluster, which lists the interface for it. But, aas, I am not at work..
If you haven't figured it out in 2 weeks, I'll see if I can figure it out. We don't make the cluster for it, but it should be built to spec, and I remember there's a section regarding seat belt minder...
Old December 23rd, 2005, 08:27 AM   #3
clarkstoncracker
lol
Those jackass engineers should at least make the "minder" start reminding AFTER the truck is taken out of park...
Old December 23rd, 2005, 09:34 AM   #4
Bones
Bones's Avatar
that screws comonality with the manuals...
If Jesus can't find it, I'll look it up.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old December 23rd, 2005, 09:44 AM   #5
Bones
Bones's Avatar
i'm assuming you have keyless entry?
what about heated seats?
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old December 23rd, 2005, 09:56 AM   #6
Bones
Bones's Avatar
this computer doesn't have the right programs to view the prints and follow the wires, but it will be a BN/LB (brown base, light blue stripe) wire
EDIT- Actually I just looked again.... when the seat belt buckle switch is open, it reads that the belt is buckled. When it reads that the switch is closed, it reads the belt is unbuckled. So you should just be able to cut that wire and not have to worry about the module. Although I'll be the first to admit I hate wiring... so I don't know what that will do to your restraint control mod. Best way to find it might be to locate the door chim wires. The buckle switch wire should be in the same loom as the door chime (unless it is easy to spot under the seat)
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old December 23rd, 2005, 10:21 AM   #7
bambam
MMMM.......Beer
bambam's Avatar
while on this subject does anybody know how to shut them off on a 05 ram1500 and a 05 dodge magnum??
bambam is offline   Reply With Quote
Old December 23rd, 2005, 09:38 PM   #8
smasheromalley
smasheromalley's Avatar
Sounds dumb but if you havent checked your owners manual the try that. I had an '02 Focus and there was a procedure to shut the chime off. key on - driver unlock button - key off - etc. etc.
Old December 23rd, 2005, 09:51 PM   #9
clarkstoncracker
lol
Well, I pulled out the connecter to the actual chime, but that is the same chime that is the lights left on chime..
Any idea what wire to cut? or can you lead me to an online schematic?
Old December 23rd, 2005, 10:06 PM   #10
Bones
Bones's Avatar
did you read my post?
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old December 23rd, 2005, 11:07 PM   #11
I would have figured the chime itself is located on the circuit board for the instrument cluster. Also makes the tick-tock sound for your turn signals..
Start tapping into wires, and connect/unconnect the seat belt and see what wire changes states.
We do the instrument clusters for the Explorer, Expedition, NAvigator, etc....
Old December 24th, 2005, 07:38 AM   #12
clarkstoncracker
lol
I misread it.. sorry..
The chime power isr iding on a white/yellow wire.. But that is not derived directly from the seatbelt.. must be a relay I am missing... I think I might just unplug my chime, and just hope I don't leave my headlights on.
thanks guys
Old December 27th, 2005, 07:47 PM   #13
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Hey, I need to do this to a '02 Explorer, for the same reasons as Kelly. I'm not wearing my seatbelt in a parking lot or lane closure for work....but can't stand the chime. And for some reason mine just got much louder within' the last two weeks.
I'll check my manual and see if anything is in there.
Old January 2nd, 2006, 06:54 PM   #14
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Was it built before 3/2002 or after 3/2002?
Old January 2nd, 2006, 07:56 PM   #15
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Before...its one of the first '02. We bought it in August/Sept of '01.
Old January 5th, 2006, 12:32 PM   #16
Kelly, did you ever get this to work?
I looked through the info I have here at work, which is for the 2006 Model year. For the 2006, the chime itself is located on the instrument cluster, with the belt minder info sent over HS CAN(the network)... So, I don't have the actual signal levels for the open and closed states..
Old January 5th, 2006, 12:48 PM   #17
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
magnum only does it when the vehicle is moving so why not just wear your seat belt when its moving?
nixxerRsixxer is offline   Reply With Quote
Old January 6th, 2006, 06:25 PM   #18
Jeeperz Creeperz
GL 4x4 Vendors
According to the wiring diagram, the switch is closed when unbuckled and open when buckled. You shoud be able to unplug the switch at the buckle and that's that (it should be a two wire, flat grey plug).
Old January 6th, 2006, 06:35 PM   #19
Jeeperz Creeperz
GL 4x4 Vendors
I'm assuming this is F250-550?
Wiring diagram shows a seatbelt switch at C323 under the drivers seat...?
Old January 8th, 2006, 01:26 AM   #20
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Thank you very much.
Page generated in 0.74334 seconds with 83 queries
