quick tire size question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 25th, 2013, 06:52 PM   #1
skife
skife's Avatar
Default quick tire size question
tires on the xj i just bought are bad, awhile ago i got a set of "rollers" from a friend they are all 75% or more tread.
problem is, 3 of them are 235/70 r15 and one is 225/75 r15 i used a tire size calculator and the 225 is 1.2% smaller would this be alright to run without doing any damage?
Old April 25th, 2013, 07:09 PM   #2
Zach4739
2005 Willys
Zach4739's Avatar
You'll be fine
Zach4739 is offline   Reply With Quote
Old April 25th, 2013, 08:32 PM   #3
bdd1469
bdd
bdd1469's Avatar
The best way to check the size difference is with a tape measure around the tire mounted on the wheel you are running.
If it doesnt have any locker or posi in it and it is not all wheel drive the size of the tires wont hurt wont hurt any thing. It will cause spider gears to wear more, but it will be ok temporarily.
If it has all wheel drive different size tires will also add wear on the transfer case.
Old April 25th, 2013, 08:39 PM   #4
Lower the air pressures in the other tires till equal height. Raise air pressure in the other
Old April 26th, 2013, 02:27 PM   #5
skife
skife's Avatar
figured it'd be okay.
Old April 26th, 2013, 06:12 PM   #6
I suck cocks. Lots of them.
locally famous
but he used a calculator
Page generated in 0.23188 seconds with 41 queries
