2005 Crown Vic Police Interceptor - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 25th, 2013, 03:58 PM   #1
eagle-eye
Default 2005 Crown Vic Police Interceptor
A friend has an 05 crown victoria with about 135k on it. about a month or so ago he said the trans started slipping. He pulled over, shut it off, restarted and it drove fine. Parked it in his driveway and wanted to have it looked at before driving again to avoid more damage. When he tried to start it again, nothing. Fuel pump doesnt come on, no crank or click, no lights in the dash are working. Here is the kicker, headlights, tail lights, interior light and blower motor all work. Radio, windows and mirrors dont. I think it sounds like a pcm gone bad but i need advice before i willy nilly replace something. All fuses have been checked and verified. Any help is greatly appreciated. Thanks!
eagle-eye is offline   Reply With Quote
Old April 25th, 2013, 04:09 PM   #2
jerm97xj
I fixed it!!!
jerm97xj's Avatar
Get a volt meter. Check the voltage at the battery, starter, and S terminal wire at the starter when turning the key to crank or jumping the starter relay. That will give you a start on diag. You are a looooooong ways from putting a pcm in. Then you would have to figure out how to program it and theft deterrent.
jerm97xj is offline   Reply With Quote
Old April 25th, 2013, 04:29 PM   #3
eagle-eye
s terminal gets no signal at all, battery is a steady 12.6v. engine just cranks with jumping power with battery staying at 10.8 volts.
Old April 25th, 2013, 04:53 PM   #4
Check the neutral safety or MLPS I think ford calls it....multiple level position switch nor something stupid like that. Should be on the trans where the shifter is at.
Old April 25th, 2013, 04:59 PM   #5
eagle-eye
with the key in the on position, should i be able to put my reader on it to see if the pcm is getting power?
Old April 25th, 2013, 05:00 PM   #6
eagle-eye
also brake shift interlock doesnt work with the key on, if that helps.
Old April 25th, 2013, 05:24 PM   #7
Bones
Bones's Avatar
do the brake lights come on?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 25th, 2013, 05:27 PM   #8
Toyfish
Toyfish's Avatar
I just did a 03 run a jumper wire to the fuel pump relay and see what happens
Sent from my DROID X2 using Tapatalk 2
Old April 25th, 2013, 05:31 PM   #9
eagle-eye
yeah, brake lights come on. on the fuel pump relay it wouldnt matter, engine doesnt crank, doesnt even click.
Old April 25th, 2013, 06:04 PM   #10
GREASYHANDS
GREASYHANDS's Avatar
Ignition switch
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old April 25th, 2013, 07:53 PM   #11
eagle-eye
it has already been replaced.
Old April 26th, 2013, 03:25 PM   #12
eagle-eye
put the scanner on it, scanner powered up but said link communication error
cannot communicate with vehicle. any thoughts?
Old April 26th, 2013, 04:11 PM   #13
That's typically a blown fuse.
Old April 26th, 2013, 08:10 PM   #14
frdboy
frdboy's Avatar
Those had a main wiring harness in the RF corner of the car that liked to get damaged or corrode causeing all kinds of strange stuff.
Old April 30th, 2013, 07:47 AM   #15
eagle-eye
Checked rf wiring harness, all is well. Rechecked all fuses with test light and here is what I found. Non of the fuses labled ign on/run/acc/start are getting any power. Re replaced the ign switch to no avail, fuel pump doesn't come on, no relays click. Pcm relay feed and keep alive fuses all have power but still no reaction from the car.I don't understand how it could be fine one day and not the next...
Old April 30th, 2013, 07:53 AM   #16
frdboy
frdboy's Avatar
Sounds like a bad wire or connection. Here is your powers in and out of the ign. sw. Need to start doing some voltage drop testing to see where your issue is.
Old April 30th, 2013, 07:58 AM   #17
fsumotorhead
N8KVB
fsumotorhead's Avatar
Search all your common grounds.
Page generated in 0.40922 seconds with 74 queries
