ZJ: Zj 318 motor swap from a Dodge. Starter location? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 25th, 2013, 08:18 AM   #1
Trick
94 Zj, 33s and lockers
Trick's Avatar
Default Zj 318 motor swap from a Dodge. Starter location?
Hey guise,
I have a 97 Zj with a 318 5.2 motor. The motor is blown and needs to be replaced. I found a 318 5.2 out if a 96 dodge.
Someone is telling me, I need to use a 5.2 out of a ZJ only, because the starter is on the wrong side and I would need a lot of fab work to make it work. Any truth to this?
Trick is offline   Reply With Quote
Old April 25th, 2013, 09:28 AM   #2
Toyfish
Toyfish's Avatar
Nope doesnt matter looks like any 5.2 from 94-97 will work
Sent from my DROID X2 using Tapatalk 2
Old April 25th, 2013, 10:14 AM   #3
ajmorell
The starter mounts to the transmission....
Old April 25th, 2013, 10:17 AM   #4
Trick
Trick's Avatar
ppfff... ok thanks!
Old April 25th, 2013, 11:01 AM   #5
jerm97xj
I fixed it!!!
jerm97xj's Avatar
I think this was true on the OLD 2.8 chevy motors. The rwd 2.8 from a blazer had the starter on a different side then the FWD 2.8 from a cavalier. If I remember correctly.... and in this case it really does not matter.
jerm97xj is offline   Reply With Quote
Old April 25th, 2013, 02:56 PM   #6
ajmorell
Whoever told you that might have been thinking of the transmissions not the engines, the transmissions won't swap because of the starter issue.
Old April 27th, 2013, 10:24 AM   #7
Badphish
I've got 5.2 from a 94 zj if your interested
Badphish is offline   Reply With Quote
Old May 9th, 2013, 05:51 PM   #8
99sahara
99sahara's Avatar
Would a 5.2 out of a 2000 ram swap into a 96 zj with a 5.2?
99sahara is offline   Reply With Quote
Page generated in 0.20902 seconds with 47 queries
