Garage Heat options - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 25th, 2013, 08:03 AM   #1
kickstand
circling the drain
kickstand's Avatar
Default Garage Heat options
I bought one of those new fangled outdoor woodburner deals.
I want to heat my garage. I have limited wall, ceiling, and floor space. I have a small ass garage and its filled with shit.
I don't want to spend a shit ton of additional money.
Quick thoughts
1. See how feasible it would be just to run a heat duct out there from existing furnace. Advantages to this option is it's nice and simple if I can easily route something out there.
2. Some sort of radiant heat option where I could just run the warm water from the outdoor boiler through it.
3. Some sort of option like option 2 with a built in blower.
Option one seems cheapest, but probably least efficient.
Option two seems simplist, and I like the feel of radiant heat, but it will take up some space somewhere, though I have some options (under work bench for example I could clear some space)
Otion three would probably be the best option as far as efficiency and output, but costliest.
Anyone have a good source for a cheap old school cast iron radiator?
Old April 25th, 2013, 08:05 AM   #2
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
search "unit heater" run hot water lines to it and bam done heat on demand
Old April 25th, 2013, 08:07 AM   #3
kickstand
circling the drain
kickstand's Avatar
I wanted to be a cheapass.
Old April 25th, 2013, 08:07 AM   #4
Big_Awesum_Jeep
Unit heater +1
Big_Awesum_Jeep is offline   Reply With Quote
Old April 25th, 2013, 08:08 AM   #5
Strangler
Strangler's Avatar
That took me to dirty sites.
Old April 25th, 2013, 08:08 AM   #6
kickstand
circling the drain
kickstand's Avatar
http://www.ocsind.com/cast-iron-radiators.php
Old April 25th, 2013, 08:08 AM   #7
hosejockey4506
Visiting Admin
they can be found cheap honcho paid a 24 pack of bud light for his if i recall. they use them in older building with boiler heat, so they are all over the place
Old April 25th, 2013, 08:13 AM   #8
Verbalkint99
XJ Newbie
Verbalkint99's Avatar
I know spring is taking its time...but what about just opening the door?
Verbalkint99 is offline   Reply With Quote
Old April 25th, 2013, 08:14 AM   #9
kkodet
kkodet's Avatar
I had a wood boiler at my old place and tried the cast iron radiator thing in my one car garage. No insulation in garage, and it got up to around 45 degrees or so inside.
Old April 25th, 2013, 08:17 AM   #10
creeping death
I'm that guy.
creeping death's Avatar
water from your boiler, radiator from a junkyard vehicle or something, put a fan behind it.....
it works.
Old April 25th, 2013, 08:23 AM   #11
af26yrs
af26yrs's Avatar
it works.
My thoughts.
af26yrs is offline   Reply With Quote
Old April 25th, 2013, 08:25 AM   #12
disturbedsledneck
disturbedsledneck's Avatar
it works.
This ^
I know of several guys with old used school bus radiators in their shops with a simple box fan behind it and it works good. Cheap too.
disturbedsledneck is offline   Reply With Quote
Old April 25th, 2013, 08:28 AM   #13
kkodet
kkodet's Avatar
it works.
Even better. I just remembered a buddy of mine used an old household a/c unit. The outside kind, not the window kind. He ran the water through the tubes and wired the fan to run backwards. The fine aluminum coils have more surface area than a radiator. He heats a 3,000 sq ft barn and it puts out wicked heat!
Old April 25th, 2013, 08:32 AM   #14
kickstand
circling the drain
kickstand's Avatar
My garage is insulated. 50* would be plenty warm.
Old April 25th, 2013, 09:57 AM   #15
busyfixin
Balls Deep
busyfixin's Avatar
I've seen several of the truck radiator set-ups, and they work very well for the cost. The better the fan, the better they work, although a basic Walmart box fan works just fine.
Old April 25th, 2013, 11:10 AM   #16
special ed
Pickup Agent
special ed's Avatar
My shop heater has been through several encarnations. I recommend a squirrel cage fan, for quietness and airflow. You want high pressure, low volume. Currently I am using an old furnace and a radiator from a GMC Topkick 366 gas. It heats a 32x48x12 barn.
special ed is offline   Reply With Quote
Old April 25th, 2013, 11:33 AM   #17
firehawk
Live Action!
firehawk's Avatar
Pic of the backside?
Old April 25th, 2013, 11:39 AM   #18
Big_Awesum_Jeep
Do you say that to dudes a lot?
Old April 25th, 2013, 11:49 AM   #19
firehawk
Live Action!
firehawk's Avatar
No but your mom played along, slut!
Old April 25th, 2013, 12:11 PM   #20
Bones
Bones's Avatar
you have an outdoor boiler?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Page generated in 0.45222 seconds with 82 queries
