Hp44/9" axle shafts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 24th, 2013, 05:54 PM   #1
pelton54
member
pelton54's Avatar
Default Hp44/9" axle shafts
I'm looking for some axle shafts that will fit F-250 high pinion dana 44 and a 9"
Both are from a 79 F-250
pelton54 is offline   Reply With Quote
Old April 24th, 2013, 06:18 PM   #2
redneck87
i have the drive side axle shaft from a 78 ford bronco. it came out of dana 44 high pinion.
redneck87 is offline   Reply With Quote
Old April 25th, 2013, 07:38 AM   #3
pelton54
member
pelton54's Avatar
Pm sent
Old April 26th, 2013, 05:50 AM   #4
pelton54
member
pelton54's Avatar
Found 44shafts need some for the 9" now.
Old April 26th, 2013, 06:00 AM   #5
curbdog17
Mini Van
curbdog17's Avatar
Make sure that the long inner shaft is the right length. I run a f250 d44 too and it has a longer shaft than the half ton axles.
Old April 28th, 2013, 08:06 PM   #6
pelton54
member
pelton54's Avatar
Still looking
Old April 28th, 2013, 08:32 PM   #7
bluminade
Bluminade Has Arrived
bluminade's Avatar
i have 2 axle shafts for the 9" , both need wheel bearings,seals and one needs wheel studs. i also have a locker and carier for a 9".
if interested pm me.
bluminade is offline   Reply With Quote
Old April 28th, 2013, 09:05 PM   #8
pelton54
member
pelton54's Avatar
Pm sent
Old April 29th, 2013, 06:50 PM   #9
pelton54
member
pelton54's Avatar
Page generated in 0.24455 seconds with 50 queries
