septic tank and drain fields - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 24th, 2013, 04:40 PM   #1
Bruster
Default septic tank and drain fields
Well with all this rain we been having im starting to think we have a drain field problem at the house.Had the tank pumped the other day and water was back filling into the tank.Guy pumping the tank told me this is a sign of a clogged or damage field that isnt working properly.
Anyone ever dug one up to replace/fix?
try to do myself or pony up the funds to have it done
Old April 24th, 2013, 04:42 PM   #2
bigbchevy
missmrgreenagain
bigbchevy's Avatar
It's really easy to do your self
H.o.r.e
Old April 24th, 2013, 04:45 PM   #3
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
there is nothing to them. i have put in a few of them in the last couple years. rock, pipe and a level is all you need
Old April 24th, 2013, 04:49 PM   #4
GREASYHANDS
GREASYHANDS's Avatar
I think a shovel might come in handy too
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old April 24th, 2013, 04:51 PM   #5
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Mini excavator> shovel
H.o.r.e
Old April 24th, 2013, 04:52 PM   #6
hosejockey4506
Visiting Admin
thats alot of hand digging i would recommend a mini excavator or you could hire it done and use a check book.
eric are you in a city or township
Old April 24th, 2013, 05:00 PM   #7
GREASYHANDS
Excavators are for pussies
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old April 24th, 2013, 05:15 PM   #8
oilburner350
oilburner350's Avatar
Excavators are handy for removing your neighbor's car from their driveway. Not only can you use the excavator on the drain field you can dig random holes. I am surprised Kodiak hasn't cleaned his yard this way yet.
oilburner350 is offline   Reply With Quote
Old April 24th, 2013, 09:03 PM   #9
tsaguy
Semper Fidelis
tsaguy's Avatar
Digging by hand is easy, but time intensive. Seems like forever before you see a result.
tsaguy is offline   Reply With Quote
Old April 24th, 2013, 09:13 PM   #10
Elvis13
What exactly is indicating your field is bad?
Septic tanks will fill up after a pumping and with this much ground water I wouldn't immediately assume a problem.
Old April 24th, 2013, 09:23 PM   #11
Disco Stocker
№ ℮ Ђ ώқ Θה ς├│ﺝ
Disco Stocker's Avatar
I know 3 different houses with the same problem. The ground is just too wet to jump to conclusions.
Disco Stocker is offline   Reply With Quote
Old April 24th, 2013, 09:44 PM   #12
bear jocham
bear jocham's Avatar
What type of soil is your yard did the person that built you drainage field use perforated pipe from the house to the tank if they did it would fill your tank with ground water or your tank could be cracked and lettin ground water in or the way you talked about a clogged field I have built a lot of sytems and repaired a lot of them repairing is a nasty job that takes a few days not hard to do just time consuming depending on your local codes for the layout of the field I hope I have helped a little
bear jocham is offline   Reply With Quote
Old April 24th, 2013, 10:39 PM   #13
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Exactly. If the field is saturated, replacing all the pipe isn't going to help the water will still have nowhere to go.
Old April 24th, 2013, 11:25 PM   #14
L4CX
Out for the Summer!
L4CX's Avatar
Originally Posted by bear jocham View Post
What type of soil is your yard? Did the person that built you drainage field use perforated pipe from the house to the tank? If they did, it would fill your tank with ground water, or your tank could be cracked and lettin ground water. The way you talked about a clogged field. I have built and repaired a lot of them. Repairing is a nasty job that takes a few days not hard to do just time consuming. Depends on your local codes for the layout of the fld I hope I ave helped a little
Punctuation. Makes you appear knowledgeable.
I'm not usually a grammar Nazi.
L4CX is offline   Reply With Quote
Old April 25th, 2013, 01:47 AM   #15
Jcj5
There should be sand under the pipe with 6 inches oh 6a stone between the sand and pipe then another 2 inches of 6a on top pipe from house to tank should be solid heavy wall pipe
Jcj5 is offline   Reply With Quote
Old April 25th, 2013, 05:16 AM   #16
g00fy1
Si Vis Pacem Para Bellum
g00fy1's Avatar
^^ This
Happened to my Dad's place, the septic cleaning company just kept sucking it out of the tank. Ended up costing my Dad twice as much to drain it because they charged by the gallon.
The guy said it's pretty normal for the field to get saturated like that this time of year with this much rain.
Life is tough, even tougher if your stupid. - John Wayne
g00fy1 is offline   Reply With Quote
Old April 25th, 2013, 06:24 AM   #17
Give it a few days and see if it gets better.
Page generated in 0.33050 seconds with 73 queries
