Ford Dana 60 and 14 bolt parts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 24th, 2013, 09:48 AM   #1
buttercr125
I work out
buttercr125's Avatar
Default Ford Dana 60 and 14 bolt parts
I am looking for the spindle nuts for a 78-79 front Ford Dana 60 and a rear 14 bolt ff.
Old April 24th, 2013, 12:18 PM   #2
hamsmotorsports
hamsmotorsports's Avatar
Dorman sells them.
hamsmotorsports is offline   Reply With Quote
Old April 24th, 2013, 01:29 PM   #3
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Locally you can get a lot of D60 parts from Jeff's Bronco Graveyard if you need them quick.
http://broncograveyard.com/bronco/i-...asher-kit.html
or the better Stage 8 version:
http://broncograveyard.com/bronco/i-...-assembly.html
Old April 24th, 2013, 11:04 PM   #4
bigblockford79
Big Block Ranger
bigblockford79's Avatar
I may have a stock set for the 60, will look when I get home.
NOT sent from an iPhone
Old April 25th, 2013, 08:18 AM   #5
buttercr125
I work out
Originally Posted by hamsmotorsports View Post
Dorman sells them.
Do you know the dorman part number? I thought I looked and couldn't find the outer nut.
Page generated in 0.22749 seconds with 38 queries
