TJ: Engine swap that won't run... need ideas - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 24th, 2013, 08:01 AM   #21
tcxtreme1000
Mud Slut-Hit Every Hole!!
tcxtreme1000's Avatar
I'm hoping its a 2002 harness but I really don't have anything to compare it to.
Sent from my ADR6400L using Tapatalk 2
tcxtreme1000 is offline   Reply With Quote
Old April 24th, 2013, 08:08 AM   #22
tyzstuff
[ ]lllll[ ]
tyzstuff's Avatar
Did you by chance not have the distributor drive gear lined up properly when installing it into the new engine?That was a slight issue I had once with my sons 01 sport 4.0L.Then it had to be synced with the scanner to operate properly.
tyzstuff is offline   Reply With Quote
Old April 24th, 2013, 08:24 AM   #23
frdboy
frdboy's Avatar
If you had the cam sensor out it could be installed wrong.
Old April 24th, 2013, 08:37 AM   #24
tcxtreme1000
Ya that's where I'm at with it. Pretty sure its indexed wrong after talking to a few others. I'm starting their.
Old April 24th, 2013, 09:16 AM   #25
Wramblerguy
Wramblerguy's Avatar
I would say its timing either mess with the cam sensor to get the timing close enough or you have to find someone that can reset the timing to 0
3rd generation jeeper
Old April 24th, 2013, 09:38 AM   #26
tcxtreme1000
Fixed. Thanks guys. I put it at tdc and reinstalled the cam sensor. Runs good.
Old April 24th, 2013, 11:21 AM   #27
skife
skife's Avatar
sounds like cam timing is off.
Page generated in 0.29485 seconds with 44 queries
