TJ: Engine swap that won't run... need ideas - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 23rd, 2013, 07:40 PM   #1
tcxtreme1000
Mud Slut-Hit Every Hole!!
tcxtreme1000's Avatar
Default Engine swap that won't run... need ideas
So I have a 02 jeep wrangler. The PO had put in a 99 4 liter and I blew that one up so I installed a 2006 4 liter that I was told is new and has only 50 miles on it and after internal inspection I have no reason to doubt it. This new motor came complete with all the 06 sensors in it along with all sheet metal and everything it was even sitting on a chrysler crate. So the motor has not been run in about 5 years and I have swapped out all the sensors from the old motor to the new one and all the plugs are connected along with a new clutch and flywheel. Now when I try to start it, it just back fires and acts like its way out of time.... this ran fine last week on the old motor. I pulled the crank sensor to inspect and it seems fine. I plan on buying a new one tomorrow to try it but I'm pretty sure its something else.
Anyone have any ideas. Help would be appreciated.
Sent from my cm_tenderloin using Tapatalk 2
tcxtreme1000 is offline   Reply With Quote
Old April 23rd, 2013, 07:44 PM   #2
jeepnxj96
jeepnxj96's Avatar
Do you have a plug wire flipped somewhere possibly? PCM not liking the new motor? sometimes they run like crap for a couple warm up cycles
Old April 23rd, 2013, 07:47 PM   #3
tcxtreme1000
Their are not any plug wires on these years. It won't even run a little.
Old April 23rd, 2013, 07:49 PM   #4
firehawk
Live Action!
firehawk's Avatar
No plug wires?
Old April 23rd, 2013, 07:49 PM   #5
firehawk
Live Action!
firehawk's Avatar
Check for fuel pressure? Check for spark?
Old April 23rd, 2013, 07:50 PM   #6
tcxtreme1000
No. Lol. They have a rail with coils. No distributor.
Old April 23rd, 2013, 07:51 PM   #7
tcxtreme1000
Fuel pressure good. Spark good.
Old April 23rd, 2013, 07:55 PM   #8
cj65
cj65's Avatar
I would venture in to the PCM not being compatible with the new engine.
Old April 23rd, 2013, 08:00 PM   #9
firehawk
Live Action!
firehawk's Avatar
Timing, like a different cam? What else could be off?
Old April 23rd, 2013, 08:01 PM   #10
firehawk
Live Action!
firehawk's Avatar
And make sure the battery is fully charged. and your grounds are good if not best.
Old April 23rd, 2013, 08:10 PM   #11
tcxtreme1000
OK its not the battery lol. 99% sure its not the pcm as all the sensors have been swapped over. The 2 motors are now identical. I'm pretty sure it has to do with the CPS or flywheel or cam sensor. Does anyone have any experience in this area. I have checked and rechecked the obvious. I just don't want to start swapping parts on something I drove less than a week ago.
Old April 23rd, 2013, 08:22 PM   #12
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I would verify that the number of cam and crank teeth between the years is the same.
JohnnyJ is online now   Reply With Quote
Old April 23rd, 2013, 08:28 PM   #13
pigfat
GONE COMMANDO
pigfat's Avatar
is the cam sync set properly?
pigfat is offline   Reply With Quote
Old April 23rd, 2013, 08:32 PM   #14
kenziefacee
Lets go and get stuck!
kenziefacee's Avatar
Did you turn the key and try to start it? :)
kenziefacee is offline   Reply With Quote
Old April 23rd, 2013, 08:34 PM   #15
firehawk
Live Action!
firehawk's Avatar
Old April 23rd, 2013, 08:36 PM   #16
masterbeatty
masterbeatty's Avatar
So are you running the 99 computer? Was the 99 a coil pack or dis?
Old April 23rd, 2013, 10:08 PM   #17
frdboy
frdboy's Avatar
Did you reuse your flywheel or the new one? sounds like a cam/crank sync. issue but looking at Chry. repair info it should be the same.
Best way to check would be a 2 chan. lab scope to look at them.
Maybe inspect the windows in the flywheel for the crankshaft position sensor, make sure they are not damaged. B
Old April 24th, 2013, 07:17 AM   #18
tcxtreme1000
No running a 2002 computer with a new flywheel bought for a 2002. With a 2006 motor.
The key? Oh Shit. That did it. Thanks kinzie. The rest of you guys are morons. :banghead:
Sent from my ADR6400L using Tapatalk 2
Old April 24th, 2013, 07:46 AM   #19
masterbeatty
You have a scanner you can hook up to see if its readn the sensors? Some will tell you crank position and cam position
Old April 24th, 2013, 07:58 AM   #20
bigbchevy
missmrgreenagain
bigbchevy's Avatar
what harness? i think most of them are a lil differnt year to year
H.o.r.e
Page generated in 0.50029 seconds with 83 queries
