Lift Help. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 21st, 2013, 05:21 PM   #1
fogls
Default Lift Help.
I have a 93 Z71 and want to do a small 2-3" lift as I drive this truck daily and use it to tow my car. I have been searching around at options but I was wondering if anyone has done something similar. I don't want a body lift looking for strictly suspension. Just hoping someone can point me in the right direction as far as add a leaf or straight up leaf swap. Or even if there is something OEM I can pull out of the bone yard. Also a good shock to use. Any help is greatly appreciated.
fogls is offline   Reply With Quote
Old April 27th, 2013, 07:43 AM   #2
trail11591
I do believe no one makes a kit for under a 4" but you can crank the torsion bars and get at least 2" those trucks u can actually crank all the way to the bump stops I wouldn't do that tho I always figured 2-3 ribs on your CV joints touching and you'll be ok.....get an alignment afterwards
Sent from my DROID RAZR
trail11591 is offline   Reply With Quote
Old April 30th, 2013, 08:49 AM   #3
TboneK1500Z28
crank your bars, put in 3/4 or 1 ton bars and crank less than the 1/2 tons, body lift, rcx makes a torsion bar lift kit but its a waste of money. id go a 4" if you wanted to keep ifs otherwise do an SAS.
body lifts i wouldnt recomment, your bed wont have as much weight capacity.
as for the rear you can use blocks, add a leaf, 1 tons and 3/4 ton rear like 5-7 pack leafs ive seen help a little. if you want it to not squat while towing then some helper springs would work, bags probably wouldnt be worht it since it doesnt tow everyday.
TboneK1500Z28 is offline   Reply With Quote
Page generated in 0.55109 seconds with 32 queries
