2000 cherokee DEATH WOBBLE - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 21st, 2013, 12:19 AM   #1
thunderbird
thunderbird's Avatar
Default 2000 cherokee DEATH WOBBLE
I just bought a cherokee and it has death wobble it's not lifted and has good tires.
I have already replaced the front shocks but still have the problem.
Where do i go from here? really need to fix this.
thunderbird is offline   Reply With Quote
Old April 21st, 2013, 08:21 AM   #2
skife
skife's Avatar
Something in the steering is loose
Old April 21st, 2013, 08:43 AM   #3
dragginwagon406
Adrenaline Junkie
dragginwagon406's Avatar
Most likely a bad or loose tie rod, drag link or track bar. Have someone wiggle the steering wheel back and forth while you watch the ends of these components for movement.
dragginwagon406 is offline   Reply With Quote
Old April 21st, 2013, 08:44 AM   #4
dragginwagon406
Adrenaline Junkie
Bad shocks and steering stabilizers don't cause death wobble, only exacerbate the situation.
Old May 12th, 2013, 11:52 AM   #5
thunderbird
thanks for the imput guys gives me places to start
Old May 12th, 2013, 12:16 PM   #6
kickstand
circling the drain
kickstand's Avatar
Something in the front end is loose or worn. Start there.
Ball joints.
Track bar
control arms
tie rods
wheel bearings
shocks
alignment
tires
Its one of those things. Usually a combination. And usually all take excessive wear while death wobbling. Just replace everything now, or everything piece by piece. Your choice.
Old May 12th, 2013, 12:20 PM   #7
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Does anybody use the search function on this site? Literally once a week somebody asks this exact same question and the answer is always the same. Something is loose or warn in the front end.
Old May 12th, 2013, 07:40 PM   #8
kickstand
circling the drain
kickstand's Avatar
Or, has anyone used google seeing as how this subject has been discussed millions of times acrossed every forum known to jeep?
Something is worn out, find it. Game over.
Old May 12th, 2013, 07:44 PM   #9
dreezy
Haggard Fab
dreezy's Avatar
But which part is worn out on HIS jeep?
dreezy is online now   Reply With Quote
Old May 12th, 2013, 07:45 PM   #10
REPBOY
Big Rig Builder
REPBOY's Avatar
Thats for him to find....
REPBOY is offline   Reply With Quote
Old May 12th, 2013, 07:50 PM   #11
kickstand
circling the drain
kickstand's Avatar
one of them or some of them or all of them
Old May 12th, 2013, 08:36 PM   #12
97 jeep Cherokee
97 jeep Cherokee's Avatar
It's more than likely the trac bar I had the same problem then replaced the trac bar and its home now you can get one at oriley for $55 that's the cheapest I found.
97 jeep Cherokee is offline   Reply With Quote
Old May 12th, 2013, 08:36 PM   #13
97 jeep Cherokee
Gone not home stupid iPhone and its auto correct.
Old May 12th, 2013, 08:52 PM   #14
Gunsworth
Gunsworth's Avatar
exactly, and if one is wonr out, the rest always seem to be right around the corner. Had to do just about all of the above when we bought ours, none were outright terrible, but all were slightly worn and together made the ride hell.
Old May 12th, 2013, 09:34 PM   #15
97 jeep Cherokee
Yeah gotta love xjs once one thing goes it all goes might as well replace everything on the front end and be done with it.
Old May 13th, 2013, 12:18 AM   #16
kickstand
circling the drain
kickstand's Avatar
Ball joints.
Track bar
control arms
tie rods
wheel bearings
shocks
alignment
tires
hmmm it's almost like............................
it's almost like someone said that already......
Old May 13th, 2013, 12:25 AM   #17
Zach4739
2005 Willys
Zach4739's Avatar
try wiggling a wheel and see what has play in it. or move the steering wheel back and forth while someone else watches the front end. should find it no problem
Zach4739 is offline   Reply With Quote
Old May 13th, 2013, 12:41 AM   #18
Hi Im Adam
x2 on track bar
x3 on replace everything
Jeeps.
Hi Im Adam is offline   Reply With Quote
Old May 13th, 2013, 04:41 AM   #19
bigdgmc
Anger Management
bigdgmc's Avatar
false.
i had a cherokee and had the same problem. replaced EVERYTHING up front. still did it. replaced the stabilizer...solved the problem.
bigdgmc is offline   Reply With Quote
Old May 13th, 2013, 06:09 AM   #20
kmanxj5011
kmanxj5011's Avatar
Originally Posted by bigdgmc View Post
false.
LOL so explain to me why i can drive my xj with no steering stabilizer and not have DW?
Stick to working on your bigdumbgmc
kmanxj5011 is offline   Reply With Quote
Page generated in 0.53543 seconds with 83 queries
