obs powerstroke no start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 20th, 2013, 06:13 PM   #1
14muddn
Default obs powerstroke no start
it's a '96 with 292k miles and it was a hard starter when I bought it in August.
My brother rolled it on it's side back in the fall so it has been sitting for a while. During that time I replaced the glowplugs and uvch on both banks along with the gaskets and plugs. 2 of the plugs were melted so I knew at least a couple of the GPs were bad. After I got everything back together in january I got it started up to move it still started rough but got going. When I moved it the shifter snapped in the steering column, awesome right?
Now I can't get it started. I drained the fuel bowl and filled it half way with diesel 911 and put the rest in the full tank of fuel (fuel from november probably doesn't help much). I'm getting black smoke out of the exhaust and it seems to get started but as soon as I let off the started it dies out.
The GPR seems to be working and I have jumped it with the same result. Before all of this happened it would start, run rough for a couple minutes, and then run just as well as my '00 powerstroke (in perfect working order).
-Did I forget to plug something in when I put the motor wiring harness back in?
-Did one or more injectors take a shit?
-could rolling the truck on its side have tripped some sensor?
I don't want to dump a ton of money into it just to have a running 300k mile 16 year old truck that is worth more parted out. If I can get it back running without spending too much I'll throw a flatbed on it and have a good work truck. If not my options are sell it as is or scrap it. I just need to do something with my driveway ornament.
Old April 20th, 2013, 07:18 PM   #2
MilwaukeeF350
Dan
You will need someone with Scanner to check out oil pressure and IPR duty to see what going.
Have you tried plug block heater for about 2 hours and see what happened. It would get couple of long cranks before it come alive. Batteries and connectors must be good condition or it crank slow.
Old April 20th, 2013, 08:12 PM   #3
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
I'd check the GP wiring harness plug on the vavle cover gasket. Those are easy to forget....
If 1 is unplugged, it won't start. Maybe the cam sensor?
Old April 20th, 2013, 08:38 PM   #4
14muddn
I'll re check the wiring and plug it in for a little bit tomorrow. It was dark and cold when I put a lot back in the truck so I might pop the valve covers and give everything a good once over.
On a positive note I pulled all of my two stoke lawn tools out of storage and most started right up when I put fresh fuel in... At least I could get a few motors to start up today
Old April 20th, 2013, 09:35 PM   #5
Grassman
2jz specialist
Grassman's Avatar
Where Is Your Oil Level?
Old April 20th, 2013, 09:56 PM   #6
Bones
Bones's Avatar
and when did you change it last?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 21st, 2013, 12:12 PM   #7
93yj06unlimited
93yj06unlimited's Avatar
Is there oil in the HPOP reservoir? If the IPR goes bad it will allow the oil to drain off causing a no start .
93yj06unlimited is offline   Reply With Quote
Old April 21st, 2013, 03:15 PM   #8
14muddn
Oil was about a quart below the full line so I topped it off. It was changed about a month before the roll over. When it rolled about a gallon came out through the air filter which was replaced with new... so I know the oil is pretty clean.
HPOP reservoir level was good.
There was a plug that wasn't "clipped" in near the turbo, it wasn't the type of clip for the EBPV?
As Milwaukee350 suggested I plugged in the heater so in a little while I'll try starting it again.
Old April 21st, 2013, 03:37 PM   #9
MilwaukeeF350
Dan
And recharge batteries too. The faster crank it should able start. If not then you will need scanner to check. I have scanner here.
Old April 21st, 2013, 04:28 PM   #10
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Why should he have to plug it in?
Old April 21st, 2013, 04:58 PM   #11
14muddn
Well, it started right up! I plugged in the connector I mentioned, put another quart of oil in, and had it plugged in for 2 hours. I'm letting it run to charge up the batteries now. I'll try starting it cold later on.
Old April 21st, 2013, 05:59 PM   #12
Grassman
2jz specialist
Grassman's Avatar
I'd Still Charge The Batteries
Old April 21st, 2013, 06:09 PM   #13
MilwaukeeF350
Dan
Cause I have work on couple PSD and I wasn't going DEAL with BURN OUT starter and dead batteries. If you try plug for 1 hour or longer you would have notice huge difference in cold start. When I am working on PSD I just plugged so know it will start easy after it fixed.
Old April 21st, 2013, 07:08 PM   #14
Suta99
Suta99's Avatar
God damn this is painful to read
Old April 21st, 2013, 07:32 PM   #15
Toivo
Feel lucky?
Toivo's Avatar
Fuck off, the guy is doing very well.
Keep up the good progress, Dan!
Old April 21st, 2013, 08:40 PM   #16
14muddn
x2 Dan is one knowledgeable and helpful guy.
Old April 21st, 2013, 10:00 PM   #17
Elvis13
IMO his posts have been getting better and easier to read. It's got to be a bitch to try and communicate when you can't hear.
It's just his advice, if you don't like it don't read it.
Old April 21st, 2013, 10:18 PM   #18
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Yeah fukc off guy
Thanks for the info 350
Old April 21st, 2013, 10:37 PM   #19
red87chevy
red87chevy's Avatar
Going thro the same problem with my powerstroke pissed me off enough to rip it out and put a cummins in so I got tons or new parts for your truck also take the tapits of and check the oil flow coming out of you injector spouts might have one hanging open but deff put on a scaner and doing the buzz test and check your ipr duty cycle and the hpop pressure and also run a cylinder con. Test should get ya running in the right direction before you thro parts at it they get costly fast!
red87chevy is offline   Reply With Quote
Old April 21st, 2013, 11:07 PM   #20
Elvis13
Are you deaf too?
Page generated in 0.39058 seconds with 83 queries
