ZJ: 96 ZJ Grand Cherokee Transmission Issue - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 20th, 2013, 11:43 AM   #1
Sil3ntP8nd8
Photographer
Sil3ntP8nd8's Avatar
Send a message via Skype™ to Sil3ntP8nd8
Default 96 ZJ Grand Cherokee Transmission Issue
I was accelerating on the entrance ramp to the highway. I had my music up but not sure if I heard something coming from the car or not. But all of the sudden the Jeep was still cruising down but felt like it was in neutral. It would rev but wouldn't drive. Had it towed back to my house and just figuring my options out now.
It has about 200k miles. I didn't notice any leaks or anything aside from some minor coolant leaking.
So my current options are to swap the transmission, rebuilt it, or just not deal with the Jeep. $1500 for the rebuild or a swap. Or just buy a brand new car.
I've been told it could be my shifter link, valve body, or my torque converter.
Has this happened to anyone else before? How much could I sell the Jeep in its current state? Thanks
Sil3ntP8nd8 is offline   Reply With Quote
Old April 20th, 2013, 12:11 PM   #2
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
It sounds like you need a trans. Find a used one and put it in yourself.
Old April 20th, 2013, 12:44 PM   #3
montecarlo33
The Violator
montecarlo33's Avatar
x2 Whatever it is sounds internal. You can check your trans fluid, maybe its way too low, either way I would start looking for another to swap out sooner or later
Old April 20th, 2013, 01:05 PM   #4
Wramblerguy
Wramblerguy's Avatar
the o/d unit took a crap on mine
found somebody local (private)to rebuild it for like $700 but it all depends on what is wrong with it
3rd generation jeeper
Old April 20th, 2013, 03:47 PM   #5
skife
skife's Avatar
sounds like the pump took a crap.
Page generated in 0.21781 seconds with 38 queries
