Rear Sway bar - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 19th, 2013, 12:15 PM   #1
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
Default Rear Sway bar
I have a 06 LJ with about 4" of lift (short arm) I'm thinking about taking off the rear sway bar. is this a BAD ideal?
CHEVYRCKS is offline   Reply With Quote
Old April 19th, 2013, 12:33 PM   #2
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
I've been running without one on my TJ. You should be fine as long as you don't expect it to handle like a sports car.
Old April 19th, 2013, 12:41 PM   #3
bigbchevy
missmrgreenagain
bigbchevy's Avatar
This
H.o.r.e
Old April 19th, 2013, 12:42 PM   #4
srlbotanical
Because I Said So...
srlbotanical's Avatar
Why do you want to take it off? Do you have disconnects for the front?
If you end up going with an Anti-rock for the front, the stock rear sway bar commplements it nicely.
An appropriate sway-bar set up is a good thing. On or off the road.
srlbotanical is offline   Reply With Quote
Old April 19th, 2013, 01:11 PM   #5
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
I was thinking it would be fine, Just thought I would ask.
Hope that it will flex better off road. No I don't have disconnects yet. Thinking about buying a currie one. but not sure.
Old April 19th, 2013, 02:36 PM   #6
skife
skife's Avatar
i ran my xj for about a year and a half without sway bars.
Old April 19th, 2013, 03:32 PM   #7
Completely valid argument unless you consider the fact that the TJ has coils in all 4 corners and your XJ has rear leaf springs
Old April 19th, 2013, 04:02 PM   #8
skife
skife's Avatar
i ran without both swaybars. *shrug*
forgot TJ/LJ is coils on all 4
Old April 19th, 2013, 06:38 PM   #9
srlbotanical
The whole argument for better flex with no sway bars is the wrong way to look at it. You may go a little higher on a ramp, but an Antirock in front and stock rear sway bar are going to provide a more stable, more predictable, and better performing (off road) TJ than if you were disconnected on all four corners.
Old April 19th, 2013, 06:41 PM   #10
robbietap
Wheel it, then take it off and wheel it.
robbietap is offline   Reply With Quote
Old April 19th, 2013, 06:45 PM   #11
firehawk
Live Action!
firehawk's Avatar
I ran my TJ on 36" Iroks with out a sway bar at all and I survived.
firehawk is online now   Reply With Quote
Old April 20th, 2013, 05:35 PM   #12
Zach4739
2005 Willys
Zach4739's Avatar
I have a 3in on mine with no rear sway bar. its not a vette so dont drive it like one youll be fine
Zach4739 is offline   Reply With Quote
Old April 20th, 2013, 07:22 PM   #13
joe_jeep
welfare wheeler
joe_jeep's Avatar
ditch the rear, if you dont disco the front.
Page generated in 0.26300 seconds with 62 queries
