windshield frame guards - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 17th, 2013, 10:25 AM   #1
2fst4you
2fst4you's Avatar
Default windshield frame guards
Anyone on here using these? Looking at genright and ucf ones who should I go with.....
http://www.genright.com/ProductInfo....0#.UW6wTMjD-Sw
http://www.undercoverfab.com/misc-ar...r-jeep-tj.html
Old April 17th, 2013, 11:17 AM   #2
I made my own.
Old April 17th, 2013, 03:25 PM   #3
2fst4you
2fst4you's Avatar
I would love to but don't have a bender
Old April 17th, 2013, 08:39 PM   #4
Tab
Tab's Avatar
I'd go with the steel genrights.
Old April 18th, 2013, 10:02 AM   #5
2fst4you
2fst4you's Avatar
Is the added strength worth the extra $60? I'm mainly using these to cover up damage but also to protect my frame. Probably will do something like Jim's later down the road as I don't feel 1/8" steel will be too strong
Old April 18th, 2013, 07:23 PM   #6
Tab
Tab's Avatar
I guess that's a decision you need to make. If you're just worried about branches and soft stuff then aluminum would be fine. I lay mine over on its side and drag it over rocks so the aluminum would be of little help. Plus I don't like how the alum ones are made in two pieces and welded together, that tells me the fit won't be as good since they bent each half with a different die radius I would think.
Old April 18th, 2013, 09:47 PM   #7
2fst4you
2fst4you's Avatar
Would 1/8 steel ones provide protection when its layed on its side or dragged through rocks?
Old April 18th, 2013, 10:17 PM   #8
Tab
Tab's Avatar
Yes, in a way. If you are in that scenario then you will have other issues to worry about. The frame would still flex, the glass could break, cowl buckle, ect.
Old April 19th, 2013, 07:08 AM   #9
2fst4you
2fst4you's Avatar
Ya either way I don't think these will protect it against a major hit so probably gonna get the aluminum ones
Old April 19th, 2013, 07:42 AM   #10
Originally Posted by 2fst4you View Post
Ya either way the steel ones are more expensive so I'm probably gonna get the aluminum ones
fify
Old April 19th, 2013, 07:50 AM   #11
2fst4you
2fst4you's Avatar
Its not that just don't see spending the extra money when either way the guards won't protect my windshield frame from a hard hit
Old April 19th, 2013, 07:58 AM   #12
1/8" steel is 3 times as strong as 1/8" aluminum. The steel ones aren't two halves welded together. The steel ones can be welded to your steel windshield frame if needed. You should be worried about not having a cage when laying on it's side or taking a hard hit, not how your windshield fares.
Old April 19th, 2013, 08:08 AM   #13
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Sounds like you already know your going to get the aluminum ones, so why bother arguing Cam
I personally would get the steel ones. They're stronger, and that's all I need to know. To me, $60 is worth the extra strength if I didn't have the proper tools to fab my own.
Old April 19th, 2013, 10:10 AM   #14
2fst4you
2fst4you's Avatar
Ok you guys changed my mind. Hopefully these things can take some abuse
Page generated in 0.22662 seconds with 65 queries
