YJ: Rear SOA with 6" stretch shock mounts... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 17th, 2013, 07:09 AM   #1
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Default Rear SOA with 6" stretch shock mounts...
Lets see what you got.
I took my rears off to measure for droop/compression thinking my shocks were to short causing my flex to be lmited. Well they are fine, but the mounts cause a binding that I need to fix.
I was going to put a bar across the frame to use as a shock mount to mount the shocks----> /-----\ like that. However, the body mount support runs rite over the axle. Do I still need that there if I have my cage tied to the frame???
Old April 17th, 2013, 10:36 AM   #2
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Maybe ill just pull bench seat and runna single seat in rear..bring shocks inside tub.....
Old April 17th, 2013, 11:46 AM   #3
Wramblerguy
Wramblerguy's Avatar
My rear shocks are inside and mounted to a price of tube welded in between the frame rails
Basically another crossmember
3rd generation jeeper
Old April 17th, 2013, 11:49 AM   #4
Wramblerguy
You can see it here if you look closely
The shocks are not mounted to the axle in this picture either
Old April 17th, 2013, 03:16 PM   #5
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I scraped the idea of running a single seat in the rear... just not enough room with the fuel cell to be comfortable.
I'll have to build a cross member. Problem is my body mounts are in the way since I moved the axle back. I need to run long shocks as well to get all the flex. I'll have to spend some time figuring it out when its nice out
Old April 17th, 2013, 04:11 PM   #6
firehawk
Live Action!
firehawk's Avatar
I have a rear seat and fuel cell in the back, just have to put the cell all the way back. I can get you pics if you want.
Old April 17th, 2013, 08:28 PM   #7
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
My issue is i'm 6'4" so I have my seat pushed very far back to be comfortable. Also, I run a bar across the B pillar for harness mounts for the front. But yes please post up some pics!
Old April 22nd, 2013, 11:41 AM   #8
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
This is what I did. I have a yj SOA with xj springs flipped for a 6" stretch.
These are 14" shocks.
Old May 3rd, 2013, 12:34 PM   #9
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I may do that. Wasn't sure how it would affect the frame though.....
Old May 3rd, 2013, 01:40 PM   #10
wilinsonlevi
Team Thumbs Up
I did it last winter and I have beat on it a few time with no issues. The plates are 1/4" and I put gussets it on a 45. I also added a piece of tube from the rollbar down to the frame.
Old May 5th, 2013, 03:38 PM   #11
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I just tied my rear cage in... so I guess that would really stiffen it up in the rear since the cage is now tied in at 6 places.
Do you have any more pics? Such as how you connected it to the axle? What spring mounts are those? I thought F250, but they look different than what are on my front.
Page generated in 0.31746 seconds with 56 queries
