Wanted: 4l60e 2wd trans for 1995 2500 silverado - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 15th, 2013, 12:56 PM   #1
built
built's Avatar
Default Wanted: 4l60e 2wd trans for 1995 2500 silverado
I have a 1995 2500 6 lug 2wd silverado with a 4l60e and need a new trans and torque converter.
I was told in another thread that I must get one from a 1995 because of a 1 year only 2-3 downshift or something along those lines.
Looking for something in decent shape near warren.
built is offline   Reply With Quote
Old April 17th, 2013, 12:17 PM   #2
built
built's Avatar
Bump
Old April 18th, 2013, 07:50 AM   #3
built
built's Avatar
Ttt
Old April 18th, 2013, 11:43 AM   #4
fdomb
fdomb's Avatar
Ive got a 2000 4l60e from a 5.7 Camaro. ^0k miles
fdomb is offline   Reply With Quote
Old April 18th, 2013, 11:44 AM   #5
fdomb
fdomb's Avatar
60k. Sorry
Old April 18th, 2013, 12:49 PM   #6
built
built's Avatar
Won't work for me. From my research I've found that 1995 Non-PWM will only interchange with the 1995 Non-PWM, the 1995 PWM will only interchange with 1995-1997 PWM
I have the pwm so I need a 1995-1997 pwm
Old April 19th, 2013, 08:18 AM   #7
built
built's Avatar
Bump
Old April 20th, 2013, 08:12 AM   #8
Tom
Because racecar
Tom's Avatar
Your research is wrong. You can only use one from a 95.
Old April 22nd, 2013, 08:20 AM   #9
built
built's Avatar
1995 had pwm and non pwm. Non pwm is 1995 only pwm is 1995-1997
I looked up my vin and my trans is pwm
Can you post information to prove this wrong?
Old April 22nd, 2013, 09:53 AM   #10
Tom
Because racecar
Tom's Avatar
Early 95 (same as 93-94) in wt models had non pwm but they are rare. You are correct about 95 up are all PWM, but you can only use a 95 because of the 3-2 downshift solenoid and computer programing. I couldn't care less if you don't believe me, because what do I know right? I'm just trying to help, Good luck with your search.
Page generated in 0.23062 seconds with 53 queries
