Another Dana 30 Question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 22nd, 2005, 08:13 PM   #1
One Arm Steve
I was born in the desert
One Arm Steve's Avatar
Question One more Dana 30 question
Anyone Know If The Xj An Tj Share The Same Axle Housing ?? Same Width Ect.?? Ok so TJ's use a low pinion. Here are a few more Questions: Has anyone had any luck at repairing a slightly bent front axle??? (damage is to the short side) The only way I can tell its bent is that the wheel bearing\hub is not flush when bolting it to the knuckle I have to use the bolts to pull the bearing into the knuckle. The welds that hold the tube in the pumpkin leak also. I've put a few thousand miles on it since the damage with no problems. I've been told Clyde's Frame and Wheel in Pontiac can repair it what do you think????? The damage is minimal. Questions answered, Thanks!
One Arm Steve is offline   Reply With Quote
Old December 22nd, 2005, 08:21 PM   #2
Tonka
Tonka's Avatar
Depends on the year, 2000+ I believe were the same, before that, the Xj was High pinion. Some xj's were disconnect axles (all command trac pre 94) selec track models did not have the disconnect
Tj's have always been Low pinion (U.S. models)
Old December 25th, 2005, 09:20 PM   #3
amc78cj7
amc78cj7's Avatar
They're interchangable (about the same width), but they are not the same axle.
amc78cj7 is offline   Reply With Quote
Old September 20th, 2006, 06:02 PM   #4
nick_n_ii
nick_n_ii's Avatar
Send a message via Yahoo to nick_n_ii
the XJ has stronger "C"s and tubes from what I've read, and is a good replacment for the TJ's axle and teh YJ for that mater. just my $.02
nick_n_ii is offline   Reply With Quote
Old September 20th, 2006, 06:17 PM   #5
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
I'm running an XJ (OK, actually MJ) D30 on my TJ right now. The TJ is not only low pinion, it is also a crush sleeve pinion axle. The Late ZJs and XJs were as well. The early ZJs used a low pinion D30 that shared gears with the CJ. However, they are all the same width, and knuckles and axleshafts interchange between them.
Old September 20th, 2006, 08:29 PM   #6
junk90xj
ALLPRO AUTO
junk90xj's Avatar
so out of curiosity will the tj44 bolt up in an xj?
http://www.apalansing.com/
Old September 21st, 2006, 06:03 AM   #7
Cooter
Cooter's Avatar
Nope, the TJ is coil sprung, and the XJ is leaf sprung in the rear.
But...An XJ D44 will bolt up just fine. (And I have several available for much cheaper than a TJ D44)
Old September 21st, 2006, 06:08 AM   #8
fr3db3ar
KISS MY AVATAR
fr3db3ar's Avatar
All along we've been talking about a front axle and you jump to the back??
Old September 21st, 2006, 06:28 AM   #9
Cooter
Cooter's Avatar
D'ooh!
Don't XJs have leaf springs in the front? I know Pete M's MJ does :dunno:
Usually when someone mentions a TJ D44, I immediately think of the rear- I never even consider the Rubicon front D44, because it doesn't give enough strength for the cost involved. (I really need to stop scanning 3 forums at the same time)
Page generated in 0.25335 seconds with 50 queries
