Xj tires size - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 12th, 2013, 02:12 PM   #1
Ebrown
Ebrown's Avatar
Default Xj tires size
I have a buddy that wants to run 245/75/15 under his 1999 Xj... From the Factory it came with 235/75/15!
So I suggested .75 coil spacer for the front and 1 shackle in the rear... Would he need longer brake lines?
He tows a 2004 Toyhauler pop-up, he want to match the tires size on the trailer so he has more tire rotation options
Would this be worth it or should he run a small lift ie Skyjacker 3" full spring lift?
Ebrown is offline   Reply With Quote
Old April 12th, 2013, 02:13 PM   #2
Toyfish
Toyfish's Avatar
Spacer lift should be fine i would go more with a 2" spacer u will need new shocks but the brake lines will be fine
Sent from my DROID X2 using Tapatalk 2
Old April 12th, 2013, 02:17 PM   #3
montecarlo33
The Violator
montecarlo33's Avatar
I have 245's on my stock jeep ZJ, no rubbing at all.
Old April 12th, 2013, 04:00 PM   #4
Ebrown
Ebrown's Avatar
He has Rs-9000 on the rear and there good for 0-3" of lift!
Old April 12th, 2013, 04:03 PM   #5
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
Grab a pair of S-10 leaves and build up the packs instead of shackles. He'll thank you later. The control and firm ride I got with mine made all the difference in the world. 5 years and no sag no matter what load I put in it. Flexes pretty good too.
ckupq is offline   Reply With Quote
Old April 12th, 2013, 04:58 PM   #6
kkodet
kkodet's Avatar
They'll fit with no lift. Those are basically 30's. I have new 30 BFG AT's on stock rims on my 97 XJ and the only rubbing is full left or right, and only slightly. No bottom out issues at all.
Page generated in 0.30940 seconds with 41 queries
