CJ: '71 cj5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 11th, 2013, 12:29 PM   #1
Lynxer
Lynxer's Avatar
Default '71 cj5
Im getting ready to put a new fiberglass tub on my old CJ5, I have the old tub off and the frame painted with some farm and imp. enamel. Waiting on the tub in the mail....
Anyhow ive been going over the jeep while waiting for the tub, and my recent addition is a new brake master cyl. OEM remanufactured. Bench bled, bled rear drums, stripped the front bleeders.. vice grips bled front drums.. BUT my pedal is still soft as hell.. whats going on?
Drum is off front pass side, getting movement in pads, but its not alot..
Anyone have suggestions on adjusting//properly bleeding a full drum brake system? Ive worked on many drums, and I really didnt think this would be an issue....
Dana27 front
Dana44 rear
v6
3speed
Also looking for lift suggestions? mild?
2.5" vs 4"?
Pics just because:
Lynxer is offline   Reply With Quote
Old April 11th, 2013, 01:12 PM   #2
How much tire are you looking to run under it? I always ran 31s with no lift on my CJ5. 33s, either a 2.5 or 4", depending on if you want it low, or taller. 35s, I run a spring over with flat springs, and a little extra arch when I ran 36s and 37s. Actually, on my CJ7, I have it sprung over with 33s, and it looks good. I could clear 35s, though.
With the brakes, hmm, if you are sure you have all the air out (still using the frame mounted master cyl? Or did you convert to hanging pedals. Guessing the frame one, since you have no body....
I don't nkow if you'll get a firm pedal without the brake drums on there. Maybe put a c-clamp on the wheel cylinder, and then see if you get it firmed up.
I usually like to use a vacuum bleeder from each wheel. I don't have much experience with that setup, though, with the master cyl so low in the system. It can create some weird spots for air to get trapped.
Old April 11th, 2013, 01:35 PM   #3
Lynxer
Lynxer's Avatar
Trail rig, would like to just make some room for the 31's, maybe run 33's with some breathing room?
Would love to go spring over. But were do I find longer driveshafts? cut and weld?
Old April 11th, 2013, 05:34 PM   #4
skife
skife's Avatar
D&R driveline in jenison
Old April 11th, 2013, 06:40 PM   #5
Renegade II
Coil springs are for pens
Renegade II's Avatar
Unless you swap from the Ross bell-crank steering to a Saginaw box I'd stay at 33 or smaller tires. You should only need a couple inches of lft to do that.
Spring over on an early 5 gets you into more than just drive shaft lengthening. Drive shaft yokes bind at droop (esp. that tiny u-juint front), re-mount shocks to axles, drop t-case or driveline, move all the brake lines, caster vs pinion angle vs cut and turn knuckles, cross over steering, 27's bend easy, etc...
If it's been setting long or very little use, throw new wheel cyl's on all around & power bleed the brakes. If it's still orig or old brakes the pistons can corrode and seize in the cyls and not work or bleed correctly.
Good luck
Old April 12th, 2013, 02:41 PM   #6
Lynxer
Lynxer's Avatar
Ive been on a literal hunt for a decent tub. Ordered a cheapo Jcwhitney tub 2 weeks ago, still hasn't shipped so im about to cancel the order. They keep giving me the run around. Ive heard bad reviews, but ive seen a cj7 tub from them and it looked good to me?
anyway getting frustrated, want to get this sucker back together. Not worried about how pretty it is, just needs a floor!
my tub hunt continues.
Old April 9th, 2014, 12:02 PM   #7
jeepbob
I have a 4WD hardware that has been used hard. It has some cracking in the gel coat but not bad for a 25 year old body that has never been in the garage.
jeepbob is offline   Reply With Quote
Old April 9th, 2014, 12:58 PM   #8
Outdoors
Field Repairs
Outdoors's Avatar
x2 on the 4WD tub.
As for the brakes, the nice thing with the old CJ's is they normally will gravity flow bleed. Trickle out the rears for a bit to see if you don't have some air in there. Not sure if the 71 had a proportioning valve, but air in it could be the issue.
Outdoors is offline   Reply With Quote
Page generated in 0.30643 seconds with 47 queries
