hpi blitz 2wd truck - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 11th, 2013, 07:15 AM   #1
Toyfish
Toyfish's Avatar
Default hpi blitz 2wd truck
i have a hpi blitz 2wd stadium truck has upgraded electronics with a brushless motor no reverse. i have upgraded the shocks to piggyback shocks from tower hobbies, also has brand new tires also comes with original wheels and tires which r bald (i used those on the pavement). Also comes with another street car body everything is here just needs a battery to run it. looking for $250 obo
Old April 12th, 2013, 07:19 AM   #2
Toyfish
Toyfish's Avatar
bump for a fast car!
Old April 12th, 2013, 08:17 AM   #3
LS6454
LS6454's Avatar
What bl system is in it ?
RX/TX ? am,fm or 2.4 ?
Stock servo ?
LS6454 is offline   Reply With Quote
Old April 12th, 2013, 08:20 AM   #4
Toyfish
Toyfish's Avatar
i think the servo is still the stock one im not sure on the rx/tx i know its a novak brusless system with no reverse speed just a brake on it but ill have to look at it tonite to see what it is
Old April 12th, 2013, 08:30 AM   #5
LS6454
LS6454's Avatar
It has reverse you just have to program the esc. Find out what esc it is or take a picture of it. I can tell you how to program it for reverse. Also what turn is the motor ?
Old April 12th, 2013, 08:31 AM   #6
Toyfish
Toyfish's Avatar
man this this has been collecting dust on the shelf for around a year since the battery took a shit im not sure on the motor turn ill look at it and get all this info tonite after work
Old April 12th, 2013, 05:34 PM   #7
Toyfish
Toyfish's Avatar
It has a high torqe servo novak gtb brushless system with a trinity motor unsure of the turns, rf-6 am receiver (stock)
Sent from my DROID X2 using Tapatalk 2
Old April 12th, 2013, 08:34 PM   #8
LS6454
LS6454's Avatar
set your throttle trim to 0 on your tx. with the transmitter on, turn on your esc while holding the one touch programing button down (located next to the on/off switch). hold it until the red led turns on once this happens release it. next pull your tx to full throttle and hold until led turns green. now go to full reverse until green led starts blinking. return tx to neutral position esc will go to neutral red led.
once youve done this you can program your esc it has 5 brushless profiles with esc on, hold programming button down. a series of leds will turn on and off. hold until all 4 leds turn on then release. they will then blink to indicate which profile is selected. profiles 2 and 5 are the only ones with reverse. I use profile 5 it only uses 25% rev. as profile 2 uses 100%. to change profiles hit and release program buttin leds will blink number of times for which profile is selected. ie 1 blink = prof. 1, 2 blinks = prof. 2, etc...
Old April 12th, 2013, 10:04 PM   #9
Toyfish
Toyfish's Avatar
Wow thanks i had no idea my crawler has a card thing u plug in it to program it
Page generated in 0.24363 seconds with 50 queries
