nylon tube or steel pipe air lines - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 10th, 2013, 09:54 PM   #1
Junkyard
Junkyard's Avatar
Default nylon tube or steel pipe air lines
Just got my compressor all wired up and am ready to run some lines. Has anyone used the push connector nylon air line kits? Leaning towards steel pipe but figured i would get some input. Any pros and cons or other suggestions would be helpful. Thanks
Junkyard is offline   Reply With Quote
Old April 10th, 2013, 10:00 PM   #2
Curious as well. I have a bunch of copper left over from a previous plumbing project, so I might do that.
Old April 10th, 2013, 10:00 PM   #3
robbietap
Inside a garage? Poly lines hold up just fine and simplify things for install.
robbietap is offline   Reply With Quote
Old April 10th, 2013, 10:03 PM   #4
Junkyard
Junkyard's Avatar
yea thats why i was thinking about them could run all the lines in an hour. But it seems to be more expensive and i worry about the joints leaking over time.
Old April 10th, 2013, 10:03 PM   #5
Junkyard
Junkyard's Avatar
And yes it is inside a garage
Old April 10th, 2013, 10:05 PM   #6
BlooMule
Old School
BlooMule's Avatar
Poly is fine, just be careful plugging in air lines when it's really cold.
Main advantage to poly is no rust build up to break loose and fukk up your air tools.
-rw-rw-rw
BlooMule is online now   Reply With Quote
Old April 10th, 2013, 10:05 PM   #7
Bones
Bones's Avatar
why would you not run poly?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 10th, 2013, 10:07 PM   #8
dfm_13
dfm_13's Avatar
PEX pipe works good and is easy to work with. Use barbed fittings and the crimp type clamps.
dfm_13 is offline   Reply With Quote
Old April 10th, 2013, 10:09 PM   #9
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
use PVC...its cheap and easy...this is how I ran my air lines
Old April 10th, 2013, 10:14 PM   #10
Junkyard
Junkyard's Avatar
The kit i was looking at is a push together kit didn't want to put something in and have it leak in 6 months. but its looking like the way to go.
Old April 10th, 2013, 10:15 PM   #11
Junkyard
Junkyard's Avatar
Where do i buy it at? Do they have kits with all the lines and fittings?
Old April 10th, 2013, 10:16 PM   #12
Christmas Cookie
yes spend money on a kit...why on earth would you want to save money doing it yourself with PVC
Old April 10th, 2013, 10:19 PM   #13
dfm_13
dfm_13's Avatar
http://m.homedepot.com/Plumbing-Pipe...searchNav=true
It's used for water lines in homes but is rated for 160 psi. No I have never seen kits. It would be cheaper to lay out your pipe in your shop then make a list of the fittings you would need.
Old April 10th, 2013, 10:19 PM   #14
BlooMule
Old School
BlooMule's Avatar
How long have you had the PVC lines? I'm curious as to how well it holds up.
-rw-rw-rw
Old April 10th, 2013, 10:21 PM   #15
Christmas Cookie
two years...its 1/2" schedual 40 rated at 600psi...I think my compressor would explode before it reached 600psi...I use threaded end caps to brass barbs to switch to soft line to a hose reel
Old April 10th, 2013, 10:24 PM   #16
Junkyard
Junkyard's Avatar
After the 15 trips back and fourth to the store to extend the power wires going into my garage, put in a new fuse panel, run the new wiring for the compressor, and hook in all the existing electrical. Ill buy a fukcin kit.... but thanks for the concerned about my money
Old April 10th, 2013, 10:27 PM   #17
Christmas Cookie
looking at the truck in your avatar you could use some help...plus measuring its hard stuff these days...damn tapes always lying
Old April 10th, 2013, 10:28 PM   #18
Junkyard
Junkyard's Avatar
Help with????
And google pvc air lines and tell me what you find out
Old April 10th, 2013, 10:30 PM   #19
Christmas Cookie
Help with????
yes its bad if you run over 600psi, however I have no way of running over 600psi and neither do you
Old April 10th, 2013, 10:30 PM   #20
robbietap
Page generated in 0.33051 seconds with 82 queries
