Do Gear Brands Matter? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 31st, 2006, 10:32 PM   #1
BowtieWrangler
BowtieWrangler's Avatar
Default Do Gear Brands Matter?
ive been browsing around for 4.88s for a Dana30/Ford 8.8
ive came across many brands with great difference in price
so which are the quietest and best gears to get?
D30
PORC(performance offroad center)-4.88 with Master Install for $169.99
Yukon Gear-4.88 $149.99
Alloy USA-4.88 $149.99
Superior Gear-4.88 $199.99 or 153.99 depending which vendor
US Gear(offroad outfitters)-4.88 $175
-----then there are numerous different install kits (does it matter there also im assuming you should get the install kit from the same company?)
Ford 8.8
Richmond
Motive
Ford Racing
Strange
PORC
Yukon
-----same thing with install kit
BowtieWrangler is offline   Reply With Quote
Old October 31st, 2006, 11:12 PM   #2
MayhemInc
I hate people
MayhemInc's Avatar
Superior
Strange/richmond
i had bad luck with yukons my above are the creme of the crop as far as im concerned
MayhemInc is offline   Reply With Quote
Old November 1st, 2006, 07:19 AM   #3
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
yukons are junk
get a dana spicer gear if you can or a richmond or precision or superioir if possible they seem to hold up better.
Old November 1st, 2006, 07:27 AM   #4
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
For the dana 30 in 4.88 gears Most All vendors use a "made by crown" gear and box with their label. As far as the 8.8 I reccomend Motive gear and use the Italy made version. Strange and Richmond are great for the tracks, But wear really bad for on the street driving.
Old November 1st, 2006, 08:04 AM   #5
PavementPounder
PavementPounder's Avatar
I run Dana and Precision in the Ram and will run Precision 4.88's in the CJ-8 if KillerB doesn't get back to me on buying them. :tonka:
Old November 1st, 2006, 08:13 AM   #6
KILLER"B"468
Yankabilly
put them in the CJ-8
So you all know when running percison in a dana application. You either get dana/spicer... or their house gear. Most likely it is a reboxed spicer gear set.
Old November 1st, 2006, 08:36 AM   #7
PavementPounder
Nifty.
Old November 1st, 2006, 03:16 PM   #8
BowtieWrangler
so precision is a good choice for the Dana 30 then? Since i cant seem to find a straight up Dana/Spicer gear which if im understanding you correctly the precision gear could end up actually being a spicer geaer set
and since Alloy USA and Precision Gear merged together, the Alloy USA would work as well?
Old November 1st, 2006, 07:10 PM   #9
KILLER"B"468
Yankabilly
If you buy percision/superior/westcoast/sierra/DTS and some others 4.88 for the D30 it will be a boxed gear from "crown manufacturing" It is a decent gear but other than Yukon in this application those are your 2 choices. And until 1 1/2 ago yukon sold the crown gear as well. It is a decent gear set but has a VERY tiny pinion for the D30 application. Those are the only 2 companies that I know of that make a D30 4.88 for a TJ.
Old November 1st, 2006, 07:16 PM   #10
clarkstoncracker
lol
clarkstoncracker's Avatar
Call up Alex at PORC and ask him for a lesson in gears.
That guy is stupid smart in knowing the manufactor setup.
Old November 1st, 2006, 09:58 PM   #11
BowtieWrangler
PORC was who i found the best deal from but i wasnt sure how there gears are .......he had recommended running 4.10s
Page generated in 0.25184 seconds with 56 queries
