looking for a dana 30 tj 3.73 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 8th, 2013, 06:21 PM   #1
tipsyaviator
Default looking for a dana 30 tj 3.73
title says it, would take anything thats bolt on for a tj with 3.73 if the price is right, thanks
tipsyaviator is offline   Reply With Quote
Old April 11th, 2013, 06:38 AM   #2
tipsyaviator
Bump
Old April 15th, 2013, 09:37 PM   #3
tipsyaviator
Bump
Old April 19th, 2013, 06:20 PM   #4
tipsyaviator
ttt
Old April 19th, 2013, 06:32 PM   #5
Tie Dyed
O.G.
Tie Dyed's Avatar
Send a message via AIM to Tie Dyed
pm sent
2000 XJ with a 3 inch body lift
Tie Dyed is offline   Reply With Quote
Old April 20th, 2013, 02:25 PM   #6
99tj4banger
99tj4banger's Avatar
I have 3:73 gears if you cant find an axle with them.
99tj4banger is offline   Reply With Quote
Old April 20th, 2013, 04:17 PM   #7
tipsyaviator
thanks, but i'm looking for something complete. i have a feeling if i try a regear im just going to be looking for another axle soon :)
Old April 23rd, 2013, 04:58 PM   #8
tipsyaviator
still need
Old April 23rd, 2013, 05:08 PM   #9
chevytothelevy
like a rock
chevytothelevy's Avatar
i have a dana 30 sitting in my parts xj it works and is complete i dont know what you would have to change but its all there 200 cash and ill bring it to you btw it still has stock gears i think 3.55.... pm me if your interested
chevytothelevy is offline   Reply With Quote
Old April 24th, 2013, 02:24 AM   #10
noise_maker
Frustrated Monkey
noise_maker's Avatar
I got one with a 3.73 pinion in it but it would need a carrier, unit bearings and shafts.
You wouldn't need a full gear setup just the carrier shims to set the backlash
40 if interested
noise_maker is offline   Reply With Quote
Old April 25th, 2013, 07:12 PM   #11
tipsyaviator
thanks, but still hoping for something complete.
Old April 28th, 2013, 07:04 PM   #12
tipsyaviator
still need this, 3.73 hard to find? should i just be considering a regear?
Old May 7th, 2013, 06:31 PM   #13
tipsyaviator
Still need
Old May 7th, 2013, 07:48 PM   #14
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
LJs (non-Rubicon) had 3.73s stock. I have one with 53k miles from my "old" 2005 LJ (I installed 1-tons in it), but we're installing it in my daughter's XJ.
Old May 7th, 2013, 09:54 PM   #15
tipsyaviator
Thanks for the tip
Old May 10th, 2013, 07:53 PM   #16
tipsyaviator
weekend bump, still need
Old May 19th, 2013, 08:12 PM   #17
tipsyaviator
bump
Old May 19th, 2013, 08:30 PM   #18
Badphish
I have a lp 30 from 94 zj with 3.73 from a zj if your interested it's located in muskegon and should be a direct bolt in
Badphish is offline   Reply With Quote
Old May 20th, 2013, 06:37 PM   #19
tipsyaviator
does that have a u joint driveshaft hookup?
Old May 21st, 2013, 07:30 PM   #20
newdodge
jeep life
newdodge's Avatar
I have a Dana 30 with 373 gears it does have u joint hook up all they're all you have to do is put new ujoints in the axle shaft $100
newdodge is offline   Reply With Quote
Page generated in 0.54619 seconds with 83 queries
