what stall torque converter to use? 4.3/th400 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 7th, 2013, 02:09 PM   #1
peanutboozer
LET IT SNOW
peanutboozer's Avatar
Default what stall torque converter to use? 4.3/th400
I'm going to run a TH400 trans behind a 4.3 in my 95 S10 build. I'm looking for thought on what kind of stall converter to install. I know the 4.3 is small for the th400 and I want to help to bore little thing. I also don't want to run 6K on the tach all day long or rev her up to 4k jest to move. The plan is to be able the bolt in a 383 or 400 at a latter date.
thanks Chris
peanutboozer is offline   Reply With Quote
Old April 7th, 2013, 04:22 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
2000 would work well. typically 4.3s had 1900 stall converters where small blocks would have about a 1600 in a stock application.
Old April 10th, 2013, 04:40 PM   #3
AFRd_CJ5
AFRd_CJ5's Avatar
Couple things to consider.....
If you get a 6,000RPM, it does not mean you will have to hit 6,000RPM just to get moving. You could more than likely turn the idle up, put it in drive, and idle away. Most converters are rated by their flash speed.
Whatever converter you buy, will be totally different behind another motor. If your 4.3 makes 200ft lbs of torque, then you put a SBC with 450ft. lbs of torque in front of it, it will be completely different.
Even if you buy a converter that is rated at say 3,000RPM, it doesn't mean it will stall at 3,000RPM. A lot of things come into play when you're talking about your converter..... vehicle weight, engine torque, gearing, etc. all play a part.
If you're intent to get a better converter now, I would be looking more for something to go with what motor you're eventually going to have.
AFRd_CJ5 is offline   Reply With Quote
Old April 10th, 2013, 05:10 PM   #4
bdd1469
bdd
bdd1469's Avatar
Like afr said their are a lot of things that affect the convertor. If you go with a joe blow off the shelf convertor rated at 2600 it will likely work well with a mildly built smallblock. They design a convertor that they feel will work well on most peoples cars but it isnt tuned to any one combonation.
Put that same convertor behind a 4.3 or a 454 and it will stahl at completly different rpms.
I would figure out your gearing, weight, expected torque curve, and intended usage and call the manufacturer you want to use. It will likely stahl several hundred rpm before you want with the 4.3 and work great with the smallblock if you get your numbers right.
A few companies like continental offer a free redo on your convertor if you didnt get your math right the first time. They may be a little pricey for most guys but if you can send it back and have it tuned to your new motor it may be worth it.
Old April 10th, 2013, 06:31 PM   #5
peanutboozer
LET IT SNOW
thank for the in put guys. I know that a 3000 RPM stall for a stock 350 will rev past 3000 with a 454 and wont rev up to 3000 with a 4.3. By rev up i mean that if you hold the brake so you dont move in first gaer and wide open throttle.
Yes there is a lot to consider for what converter I need. My stock converter for a 350 shoud be 1400 rpm to 1600 rpm or so. I want to free up my 4.3 but dont want to go to far. If my 4.3 can only rev up th say 1200 with the brakes locked I think it will be under powered for hard up hill runs on the trail. If I'm wrong please fill me in.
Old April 10th, 2013, 06:36 PM   #6
superchevy1080
gun nut
superchevy1080's Avatar
put a 2600 stall in it, thats what i did to my old s10 blazer before I turned it into a monster and it worked great.
superchevy1080 is offline   Reply With Quote
Old April 10th, 2013, 06:41 PM   #7
superchevy1080
gun nut
Stall= rpm before the transmission hits full lockup. Most small blocks are better off with high stalls because they make most of their power at higher rpms. Big blocks are better off with lower stalls to take advantage of there low end torque.
Old April 10th, 2013, 07:20 PM   #8
AFRd_CJ5
AFRd_CJ5's Avatar
Actually, putting the vehicle in car, and going WOT with let's say a 5,000RPM stall....you're going to start moving as soon as you give it gas (you can't hold it there at say 4,000RPM without moving).
Like I mentioned, converters are rated at stall flash, meaning if you sit at an idle, let off the brake, and then go WOT, it "should" flash to 5,000 quick (if the converter is matched to your vehicle).
Old April 10th, 2013, 08:21 PM   #9
peanutboozer
LET IT SNOW
OK thanks , Its never been put that way to me.
Page generated in 0.23120 seconds with 50 queries
