cherokee door pins sagging - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 5th, 2013, 10:03 PM   #1
CHEROKEEMUDMAN01
mellow yellow
CHEROKEEMUDMAN01's Avatar
Default cherokee door pins sagging
i am looking for some replacement door pins to fix my sagging front doors on the 89xj. i dont see anyware to order them from so are they not replaceable? shound i hit junk yard and just get new hinges on door side? my doors have alot of play in them( i can lift up about 1/4 to 3/8"). been that way since i got jeep but finally want to do something about it.
i see the mod to make them removable but i dont really plan on running without them just want the doors to get off the door sill. thanks guys
CHEROKEEMUDMAN01 is offline   Reply With Quote
Old April 5th, 2013, 10:58 PM   #2
fullthrottle
2013 King of da Moustache
fullthrottle's Avatar
Send a message via AIM to fullthrottle
My 98 zj has a non clip hinge pin and I picked up "help" part that replaces it with a clip a style. Hope that helps!
fullthrottle is offline   Reply With Quote
Old April 6th, 2013, 01:35 AM   #3
MiNi Beast
MiNi Beast's Avatar
They used roll pins. Universal. But just drill out to like 3/16" and add a bolt.
And check to make sure its not the hinge itself on the body. They have a known issue of the weld tearing, so you have to reweld it and sometimes needing to add a plate behind the hinge.
Old April 6th, 2013, 07:45 AM   #4
skife
skife's Avatar
We used 3/16 bolts when we did my 91... Try to pound the roll pins out, they are hardened and will eat drill bits, unless you have a carbide cutter or something
Old April 6th, 2013, 08:24 AM   #5
amc78cj7
amc78cj7's Avatar
www.morris4x4.com
I'm not quoting idiots who promote unsafe recovery strap techniques anymore. :miff:
amc78cj7 is offline   Reply With Quote
Old April 6th, 2013, 09:50 AM   #6
CHEROKEEMUDMAN01
mellow yellow
thanks guys. ill go with the 3/16 bolt. i did check budy and it is not comming appart there yet but when i have door off im going to plate it anyway. when you did the bolt did u guys cut bottom of hing off to make door removable or did u drill all way through and weld bolt to top of hinge or put nut on bottom side?
Old April 6th, 2013, 01:52 PM   #7
skife
skife's Avatar
I put a nyloc nut on the side i could reach, its a real mother, buy a swivel.
Old April 6th, 2013, 04:01 PM   #8
MiNi Beast
MiNi Beast's Avatar
Secure it if not wanting to remove doors at all. But be cool in summer, so may want to leave option there since your already messing with it.
Old April 9th, 2013, 08:53 AM   #9
CHEROKEEMUDMAN01
mellow yellow
not to sound dumb but u guys shure the size is 3/16 for the bolt size. i have checked home depot,lowes then the bolt shops like metrics unlimited and they all say they dont have 3/16 bolts. did u guys use grade 8 or just std? im at a loss
Old April 9th, 2013, 10:14 AM   #10
CHEROKEEMUDMAN01
mellow yellow
well found some socket cap bolts in 3/16 guess this will have to do cause i cant come up with anything else
Old April 9th, 2013, 10:17 AM   #11
firehawk
Live Action!
firehawk's Avatar
That will work fine, if you need any help I am not far from you.
Old April 9th, 2013, 10:46 AM   #12
CHEROKEEMUDMAN01
mellow yellow
ty i appricate that and i am still planing on calling you on body work still trying to work out with neighbor.
Old April 9th, 2013, 12:55 PM   #13
CHEROKEEMUDMAN01
mellow yellow
well when i went to pick up the socket cap screws at lunch they gave me 10/24 machine screws and said that it measures 3/16 so if that is true then i should be good to go and have nice closing doors again for only $12
Old April 19th, 2013, 09:49 PM   #14
CHEROKEEMUDMAN01
mellow yellow
well finally took door off and it isnt 3/16 for the pins way to small. my guess is 5/16 but ill have to hit depot tomorrow
Old April 19th, 2013, 11:15 PM   #15
MiNi Beast
MiNi Beast's Avatar
Sorry yes 5/16" been a while but just pulled couple 2dr xj doors and notice size, 3/16 is small for removing roll pins.
Old April 20th, 2013, 03:01 PM   #16
skife
skife's Avatar
my bad also, you have to drill the hinges out to accept 5/16 bolts, they are just 1/4" roll pins that are in the hinges right now, they just press out, its a real pain in the ass. you can drill them but they are hardened and you'll go through a few drill bits.
Page generated in 0.26883 seconds with 71 queries
