sterling 10.25 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 5th, 2013, 06:02 AM   #1
RnRJeep
RnRJeep's Avatar
Default sterling 10.25
can anybody tell me the weekness or strengths of a sterling 10.25 i am getting it with a kingpin dana 60 front for a good price. They are going under my cherokee and i will be running 38 inch tires. Stock 4.0 for now.
RnRJeep is offline   Reply With Quote
Old April 5th, 2013, 06:11 AM   #2
curbdog17
Mini Van
curbdog17's Avatar
I dont know much about that axle, but I do not think you need to worry about strength with that tire size, and the light weight of an XJ.
I think they may have limited aftermarket support compared to other 1-ton axles.
Old April 5th, 2013, 09:52 AM   #3
Bones
Bones's Avatar
ARB lockers are expensive. That is about it for weaknesses.
Disk brake kits used to be expensive, but not anymore. Plenty of locker choices. Shafts are strong.
One of the biggest advantages is that you don't have to shave the housing like you would/should on a 14 bolt. And they are cheap...
I ran one on my old crawler
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 5th, 2013, 02:19 PM   #4
RnRJeep
RnRJeep's Avatar
ok thanks guys. I might narrow it and i havent seen any aftermarket shafts so i think i might have to go to my local mechine shop for shafts.
Old April 5th, 2013, 02:29 PM   #5
curbdog17
Mini Van
curbdog17's Avatar
Why do you need aftermarket shafts?
Old April 5th, 2013, 02:36 PM   #6
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Yeah, aren't they 35-spline, unlike most Dana 60s?
Old April 5th, 2013, 02:43 PM   #7
masterbeatty
masterbeatty's Avatar
i ran one welded under a bronco with 4.30s and 35s i dd it and beat the snot out of it and never broke the shafts. i did however shear the bolts that hold the shaft in. i broke all but 2 somehow
Old April 5th, 2013, 03:40 PM   #8
Bones
Bones's Avatar
I ran a 100% stock sterling (except for the welded diff) under a rock buggy (albeit a light one) with a supercharged V6 motor, 39" comp sticky tires and never broke a single part. Never even turned a wrench on it come to think of it.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old April 6th, 2013, 05:51 AM   #9
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I building one for my Toyota. I went with it because i have basically no money invested in it. Parts are really no more expensive for it, and you can get anything you want ( lockers, truss, disc brakes, ect, ect)
Also, like Bones said, they have good ground clearance....my stock housing is less than a quarter inch longer from axle center line to lowest point than my buddy's 14 bolt that has been cut all to hell with Ballistics shave kit.
As for narrowing it....they use two different length shafts stock....you may be able to retube it to use two of the shorter shafts to narrow it while still using stock parts.....it won't make it a lot narrower but it will some
Old April 7th, 2013, 05:59 AM   #10
RnRJeep
RnRJeep's Avatar
I would like to narrow it to stock jeep xj axel width. I will end up taking the front axel im getting to my local shop who speciality in dana 60s and have them narrow it and make shafts for it but im able to do the rear just have to take them the shafts and some measurements so they can cut and respline them.
Old April 7th, 2013, 06:01 AM   #11
RnRJeep
RnRJeep's Avatar
Thanks for all the info. What locker do you guys sugjest for the rear axle. Lincoln locker or a true locker
Old April 7th, 2013, 07:31 AM   #12
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
If its gonna see street time.....Detroit.....if it's not....weld it.
Old April 10th, 2013, 06:00 AM   #13
RnRJeep
RnRJeep's Avatar
no more street for this rig.
Old April 10th, 2013, 06:08 AM   #14
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Then weld it and be done in my opinion
Old April 10th, 2013, 08:48 AM   #15
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Rather than narrowing axles, you might want to save money by going with wheels with deeper offset.
By the time you buy custom shafts, and especially if you are paying labor on narrowing, you can likely sell your rims and go with something with more backspace.
Page generated in 0.32322 seconds with 68 queries
