Diesel Mechanic Wanted - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 4th, 2013, 08:20 PM   #1
XLJetsFan52
Just a good ole' boy
XLJetsFan52's Avatar
Default Diesel Mechanic Wanted
Im changing up my initial post a little bit. Instead of seeking information about how to do the process, i am now looking for a professional to do it for me. The reason being is that i just do not have the time nor tools to get the job done (Especially a TechII scanner) The paragraph below is my initial post, that describes what i need done. (Injection Pump Timeset) Any help is appreciated.
Just wondering if anyone could describe to me how to set the timing on my 1999 k2500 with the 6.5L TD. Reason being, is i installed a Heath Diesel Max-E-Tork computer tune. After the swap, i did the "Injection Pump Learn" process that Heath puts in the instruction. Truck ran great afterwards. Drove it around a bit, then brought it home, and shut it down. Went to start it back up, and now its idling at about 1500 rpm's, and throwing an injection pump timing code.
XLJetsFan52 is offline   Reply With Quote
Old April 5th, 2013, 11:09 AM   #2
IFS SUCKS
I like trees
IFS SUCKS's Avatar
TOOLS REQUIRED
•J 41089 Injection Pump Wrench
•J 29872-A Injection Pump Adjustment Tool
This procedure should be used after an injection pump installation or when injection timing needs to be checked or adjusted. A scan tool must be used to check or adjust injection timing. A static timing mark can be used as a reference. If a static timing mark is not present on the injection pump mounting flange, one can be scribed to further assist in how far the injection pump needs to be rotated.
INJECTION PUMP TIMING SPECIFICATION
All injection pump timing averages 3.5 degrees .
IMPORTANT: There will be no change in engine performance or vehicle driveability if injection timing is advanced during the Time Set procedure. Injection timing must be set to Injection Timing Specifications. If injection timing is not set correctly, a possible DTC P0216 may set (see DTC P0216, Conditions for setting the DTC).
1.Start the engine.
2.Run the engine to operating temperature.
3.Install a scan tool.
4.Use a scan tool to activate Time Set (if Time Set has been activated correctly, Des. Inj. Time on the scan tool will read 0.0 degrees ).
IMPORTANT: The Act. Inj. Time value on the scan tool will fluctuate. The average reading should be 3.5 degrees .
5.Act. Inj. Time (scan tool display) should be approximately 3.5 degrees . If not, continue to step 6.
IMPORTANT: If engine stalls during Time Set activation, slightly (1 mm equals 2 degrees) rotate the injection pump toward the driver side of the vehicle, tighten flange nuts and repeat Time Set.
6.If the injection timing needs to be adjusted, continue. If not, adjustment is complete.
IMPORTANT: Move the A/C compressor to the side to improve access to the injection pump lower mounting bolts.
7.Turn the engine OFF and loosen the injection pump flange nuts using the J41089 injection pump wrench.
8.Slightly rotate the injection pump using the J 29872-A injection pump adjustment tool.
9.Set Act. Inj. Time to 3.5 degrees .
IMPORTANT: It is normal for the Act. Inj. Time value on the scan tool to fluctuate. The average fluctuation of Act. Inj. Time should be 3.5 degrees .
10.Continue to repeat the procedure until average fluctuation of Act. Inj. time is 3.5 degrees .
•If the Act. Inj Time is above 3.5 degrees SLIGHTLY (1 mm equals 2 degrees) ROTATE INJECTION PUMP TOWARDS THE PASSENGER SIDE OF VEHICLE.
•If the Act. Inj time is below 3.5 degrees , SLIGHTLY (1 mm equals 2 degrees) ROTATE INJECTION PUMP TOWARD DRIVERS SIDE OF VEHICLE.
IFS SUCKS is offline   Reply With Quote
Old April 5th, 2013, 10:20 PM   #3
XLJetsFan52
Thanks IFS SUCKS. Moving this thread in a different direction now.
Page generated in 0.18358 seconds with 32 queries
