D70 hub bolts backing out. Please help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 4th, 2013, 01:48 PM   #1
knixon804
THE GENERAL
knixon804's Avatar
Default D70 hub bolts backing out. Please help
Hey guys I have a d 70u rear end that the bolts holding the axle shaft in keep coming out. They loosen up every ride. I cleaned the treads n am using grade 8 bolts. Will studs help? I just ordered 6' of B7 7/16" rod to see if it will fix it. I am using red lock tite also
2011 F-350, DELETED, INDUSTRIAL INJECTION SINGLE TURBO.... TOW PIG
UNDER CONSTRUCTION: LJ, STROKED LS, ONE TONS, 42" MTRS
JKU UD60s, 40" TRAIL GRAPPLERS, MACHETE BEADLOCKS, AEV BLOWER
OFF ROAD ANONYMOUS- PROUD TO HAVE A PROBLEM (231) 383-5664
knixon804 is offline   Reply With Quote
Old April 4th, 2013, 01:57 PM   #2
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
is it happening to both sides? you sure something isn't bent?
could could always safety wire it, but that would be a PITA.
JohnnyJ is online now   Reply With Quote
Old April 4th, 2013, 02:23 PM   #3
knixon804
THE GENERAL
knixon804's Avatar
Both sides. Not bent. I'm going to try studs first. Then I don't know. Do any other hubs fit on a d70u axle?
Old April 4th, 2013, 03:33 PM   #4
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Dumb question but are you using lock washers? I use grade 8 lock washers with grade 8 bolts, those lock washer bite hard. Never had a problem with flange bolts on my tons or Rockwells, that is weird.
Are the bolts just a shit too long maybe?
Old April 4th, 2013, 06:17 PM   #5
knixon804
THE GENERAL
knixon804's Avatar
Using lock washers n grade 8 bolts. Tried shorter bolts even. Still nothing
Old April 4th, 2013, 07:36 PM   #6
in2deep
Hole tester
do you have a shoulder on the bolts ? or is it all threaded
Old April 5th, 2013, 06:39 AM   #7
knixon804
THE GENERAL
knixon804's Avatar
I've tried both. I'm thinking studs are my answer. The threads were kinda dirty with silicone n gear lube. Lock tite couldnt set up properly
Page generated in 0.24866 seconds with 44 queries
