hp D44 truss - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 3rd, 2013, 09:03 PM   #1
Deuling
Sand Slut
Deuling's Avatar
Default hp D44 truss
I designed this truss for a buddies axle and had it cut on a plasma table. He will be linking and doing coil overs on his rig, so all the brackets will weld to the truss, and bump pads on top etc.
Thought I would share it. Turned out pretty bitchin.
Deuling is offline   Reply With Quote
Old April 3rd, 2013, 09:55 PM   #2
littletrucker
I'd hit that
littletrucker's Avatar
Not bad, could have ran it a little closer to the diff to gain a little clearance.
Old April 3rd, 2013, 10:03 PM   #3
Deuling
Sand Slut
Deuling's Avatar
Yah I should have. It was a prototype. If I make another it will be an inch shorter. Got some other things to change as well. Still I think it turned out pretty badass. The rig will sit high, so clearance isnt much of an issue.
Page generated in 0.22950 seconds with 32 queries
