compatible? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 2nd, 2013, 08:33 AM   #1
dirty1ton
dirty1ton's Avatar
Default compatible?
a friend is wondering what is compatible with a toyota t100.He wants to swap parts but doesn't know what will fit without tearing everything up in the process.axles,trannies,t-cases,etc....
dirty1ton is offline   Reply With Quote
Old April 2nd, 2013, 08:54 AM   #2
When you say 'compatible'.. what do you mean, like interchange, for parting out purposes?
The engines are the same as Tacoma. The axles are unique to the T100, I believe. I think the t-case and transmission are also tacoma.
Old April 2nd, 2013, 08:57 AM   #3
dirty1ton
dirty1ton's Avatar
yes interchangable like rangers,s10,dakotas,anything?
Old April 4th, 2013, 08:54 AM   #4
um, no. Its a toyota. Those things are not toyotas.
The only thing that is even in the same family as other parts, is the transmissions they used, since they are Aisin-Warner. But they tend to still be toyota specific inputs/outputs.
Old April 4th, 2013, 10:53 AM   #5
tgmaul
tgmaul's Avatar
theres still alot you can use the rear leafs are great for wheelin t100s are great trucks great motor great trans as long as they are 96 and newer 3.4 lt motor
tgmaul is offline   Reply With Quote
Page generated in 0.22933 seconds with 38 queries
