square body chevy parts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 2nd, 2013, 01:57 AM   #1
snafu
Default square body chevy parts
I have a bunch of chevy parts from past and present projects that need to go. I priced everything cheap enough so it goes somewhere needed instead of the scrap pile. everything is still open to offers .update. wheels are gone. The springs need bushings but are a 2 inch lift spring not sure of brand
tailgate off a 90 suburban good shape with glass 75.00
rear side doors off same suburban power locks and windows 75.00 for the pair
core support off the 90 suburban complete lights, wiring and trim grill and headlight doors have some cracks but all there 75.00
208 transfer case off 86 light half ton pickup 75.00
700r4 good for core out of the 86 blows the pump seal out 25.00
305 carb motor out of the 86 truck. 161000 miles on the clock runs good 60lbs oil psi cold complete air cleaner to oil pan 125.00
axles out of the 86 unsure of the gears in them both good shape 100 for the pair
8 foot box off the 86 rusty around the edges but solid supports on the bottom good for mudder 75.00
stock 4 leaf front springs off the 86 50.00
chevy 6 bolt rally wheels off the 86 wheels could use a repaint with center caps and trim rings and some bad 31's 75.00
I have another set of ralleys off a 78 with the d shape holes need redone have a couple of the center caps 45.00
parts are in Harrison will have everything ready for pick up this weekend will leave the 305 till last in case so somebody wants to here it run
I work 2nd shift so please no calls before 2 pm 989-429-9489
snafu is offline   Reply With Quote
Old April 2nd, 2013, 09:30 AM   #2
michigan maniac
michigan maniac's Avatar
Is the burban tail gate power window? And do you have the truck side hinges?
Old April 2nd, 2013, 10:13 AM   #3
snafu
The tailgate is power window are you needing door hinges. Right or left side 25 a side
Old April 2nd, 2013, 10:15 AM   #4
bigbchevy
missmrgreenagain
bigbchevy's Avatar
you remind me of this one guy .
H.o.r.e
Old April 2nd, 2013, 10:22 AM   #5
liftedandgifted
liftedandgifted's Avatar
Do you have pics of the 8 foot box?
liftedandgifted is offline   Reply With Quote
Old April 2nd, 2013, 10:59 AM   #6
Bigredgmc98
Not afraid of crossbows
Bigredgmc98's Avatar
Bigredgmc98 is offline   Reply With Quote
Old April 2nd, 2013, 11:30 AM   #7
snafu
Pics of box
ID:	103927   Click image for larger version
ID:	103928   Click image for larger version
ID:	103929   Click image for larger version
ID:	103930   Click image for larger version
ID:	103932   Click image for larger version
ID:	103933   Click image for larger version
Old April 2nd, 2013, 12:39 PM   #8
snafu
Bunp
Old April 2nd, 2013, 11:47 PM   #9
snafu
Bump
Old April 3rd, 2013, 07:52 AM   #10
liftedandgifted
I wish you were closer I would take that box in a heart beat
Old April 3rd, 2013, 03:24 PM   #11
spectreblazer
spectreblazer's Avatar
what style core support is it? is it the one with the two headlights and the big turn signal?
like this?
https://www.google.com/search?q=1990...F%3B1024%3B682
spectreblazer is offline   Reply With Quote
Old April 3rd, 2013, 03:59 PM   #12
kickstand
circling the drain
kickstand's Avatar
Old April 4th, 2013, 12:39 AM   #13
snafu
Bump
Old April 7th, 2013, 10:58 AM   #14
snafu
Bump
Old April 7th, 2013, 04:35 PM   #15
gomer1975
gomer1975's Avatar
great guy to deal with
gomer1975 is offline   Reply With Quote
Old April 19th, 2013, 08:58 AM   #16
kickstand
circling the drain
kickstand's Avatar
espescially if you have a crossbow
Page generated in 0.36556 seconds with 72 queries
